help stripped rear bracket bolt
Old Aug 14, 2005 | 08:46 AM
civickiller's Avatar
Default help stripped rear bracket bolt
ok i just did a ls swap using hasport mounts(3 mounts) into my 91 civic and when i was tightening down the rear bracket it stripped the middle bolt. the top one and the bottom bolts are fine, its just the middle bolt is stripped.
so does anyone know if this will hold or do i definetly have to get that 3rd bolt fixed ? the only thing im worried about is just because its the 3 mount setup, all the force from the engine is gonna be on that rear bracket. plz help, thanks
Old Aug 15, 2005 | 01:50 AM
Default Re: help stripped rear bracket bolt (civickiller)
bump
Old Aug 15, 2005 | 09:38 AM
tgreaves's Avatar
They strip all the time, I had it happen on my b16 swap..
Old Aug 16, 2005 | 08:44 AM
Default Re: help stripped rear bracket bolt (tgreaves)
really, so is anyone running around on 2 bolts in the rear bracket ? or did you get every bolt hole fixed ?
Old Aug 16, 2005 | 09:15 AM
tgreaves's Avatar
My bolt would go in but would not tighten up, I just left it there as tight as I could get it..
Jimmii
May 1, 2009 04:04 PM
117
16
Apr 2, 2009 10:18 PM
gursh d
Sep 15, 2007 02:58 PM
[Ennis_D]
Feb 28, 2007 12:29 PM
lude98SH
Dec 7, 2006 10:24 PM
