Headgasket Right?.
Old Aug 14, 2005 | 08:35 AM
Contender25
Guest
Posts: n/a
Default Headgasket Right?.
Well i got the Crx goin, it has a rebuilt bottom end with a decent stock head on the top, but i got it goin and it's shakin pretty bad and sounds like ****. It spewed alot of sludge oil out of the radiator top, plus earlier on i noticed oil leakin out with water on the side of the head before i put a heater hose on it that was missing. Just wanted to get some peoples opinion on if it is the headgasket for sure, cause im thinkin it is, it's just a pain in the *** to do.
Old Aug 14, 2005 | 08:36 AM
Contender25
Guest
Posts: n/a
Also when i clean up the block and get a new head gasket, do i have to get the head resurfaced?.
Old Aug 14, 2005 | 09:31 AM
e jay one's Avatar
Default Re: (Contender25)
well if theres antifreeze in your oil its the headgasket. does it smoke? what motor is it? its not that hard to do a head gasket. and no you dont have to resurface just check it. was the car overheated real bad?
Old Aug 14, 2005 | 11:04 AM
Contender25
Guest
Posts: n/a
All i know is i got the car with the b18 in it from a bud, and he got the motor put in by 2 guys local that rebuilt the bottom mostly, but im thinkin they use a shitty ole headgeasket prob. They're is alot of stuff that is new, and isn't, the headgasket probally is busted im guessin since thy're is like a shitload of sludge oil in the water in the cooling system.
Old Aug 14, 2005 | 11:05 AM
Contender25
Guest
Posts: n/a
I can do the headgasket it's just a pain in the *** to do on the dohc motors compared to the sohc motors.
Old Aug 14, 2005 | 11:08 AM
Contender25
Guest
Posts: n/a
BTW The motor wasn't even started until i got the car and, cause i had to figure out what was electronically wrong to get it going, then i find out it's shaken real bad and has alot of sludge mixed in with the clean water in the cooling system.
Old Aug 14, 2005 | 06:46 PM
Contender25
Guest
Posts: n/a
Im gonna go ahead and get the head pressure tested for cracks, and resurface it if it's still good, and then change out the gasket. It's spewin oil out of a heater hose i left unplugged and the radiator top.
Robotin
Mar 24, 2012 04:03 PM
scspeed
Apr 18, 2009 01:54 PM
ef 991red
19
Jan 20, 2009 04:28 AM
SlammedBlackGSR
Oct 26, 2006 06:56 PM
strsi
Apr 6, 2005 05:28 PM
