db8 door handles on dc2
Old Aug 14, 2005 | 07:25 AM
diversegsr's Avatar
Default db8 door handles on dc2
I have searched on this using different phrases but no luck
My question is that I want to use Db8 door handles ( 4- door ) the ones without the keyhole and but them on my gsr for a clean look...this should work especailly having power locks so when I want my door to unlock I just press my keypad and there you go...am I correct or do I need stupid door poppers and the only problem I see having is if my alarm goes off...usually you can put the ign key in the drivers key hole and turn and it turns off...but you should be able to use the keypad...right???
Old Aug 14, 2005 | 07:52 AM
jennifermike's Avatar
Default Re: db8 door handles on dc2 (diversegsr)
it will work with no poppers, if you battery dies u will have to climb in thru the trunk to get into the car though
Old Aug 14, 2005 | 07:55 AM
diversegsr's Avatar
Default Re: db8 door handles on dc2 (jennifermike)
does anyone have a DIY thread on this???
Old Aug 14, 2005 | 11:48 AM
EnjoyTheRideDC2's Avatar
Just remove your DC2 door handle, and connect the latch rod on the DB8 handle when you install it into your DC2 door. All you're doing is eliminating the key cylinder and the rod that connects to it. Your power door locks will function as usual, no worries.
Old Aug 14, 2005 | 11:50 AM
Default Re: db8 door handles on dc2 (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diversegsr &raquo;</TD></TR><TR><TD CLASS="quote">... and the only problem I see having is if my alarm goes off...usually you can put the ign key in the drivers key hole and turn and it turns off...but you should be able to use the keypad...right??? </TD></TR></TABLE>
The keypad will disarm the alarm.
No Door Poppers Needed.
Old Aug 14, 2005 | 11:52 AM
diversegsr's Avatar
thanks for explaining it...should be easy...weekend project
TwotoneC1Da9
Sep 23, 2011 11:54 AM
98GSRDC2
Feb 21, 2007 05:59 PM
diversegsr
Aug 27, 2005 10:35 PM
turbotegy
Jun 4, 2005 09:34 PM
hungsteR
Nov 25, 2002 09:16 PM
