edelbrock 70 mm throttle body
Old Aug 14, 2005 | 04:30 AM
animal chin's Avatar
Default edelbrock 70 mm throttle body
anyone have experience with this t.b.
i need to purchase a 70mm and edelbrock has proven reliability
Old Aug 14, 2005 | 07:07 AM
Trooper's Avatar
Default Re: edelbrock 70 mm throttle body (teh)
Very nice TB in my opinion. you will not have any passages for the IAC motor though. it does not have a honda TPS connector. if you need the pin out let me know.
Old Aug 14, 2005 | 02:04 PM
Default Re: edelbrock 70 mm throttle body (Trooper)
thats it?
Old Aug 14, 2005 | 04:34 PM
therealpoorboy's Avatar
i broke one last week. sheared the shaft in half. only used on a drag car for maybe 50-60 passes
Old Aug 14, 2005 | 04:48 PM
Default Re: edelbrock 70 mm throttle body (therealpoorboy)
now thats some helpful info......thanks again
Old Aug 14, 2005 | 05:36 PM
The Birdman's Avatar
good quality stuff... only downside is that it is a universal piece that started out as a 5.0 mustang tb.
has its own tps
A FEW SMALL PROBLEMS:
-If you aren't making a custom flange for your im, you will have to buy an adapter plate for the tb to the im for hondas.
-The tb will have to be flipped around, or your throttle cable will have to go behind the im because the tps and throttle are on the oppossite side as on a honda. If you flip it around be sure you pull from the top with the throttle cable, otherwise you'll be mashing the throttle into the side of the tb when you push down the pedal.
Overall, I think it is a good quality product but it just has a few fitment issues that need to be taken care of. I have one and I haven't had any major problems with it like the last post has but hey this is just one opinion of the million that are out there.
Old Aug 14, 2005 | 07:10 PM
Default Re: edelbrock 70 mm throttle body (jd3jdm)
we actually drilled ours to fit the stock honda pattern.
Old Aug 14, 2005 | 09:12 PM
^^yeah there are a few different ways to do it. I was already having a custom intake manifold made so I just had a different flange made and welded on.
Old Aug 15, 2005 | 09:15 AM
na200whp's Avatar
bbk offers a bolt up 70mm t/b
Old Aug 16, 2005 | 07:41 AM
cyrix12's Avatar
Default Re: (na200whp)
bro...does the bbk 70mm TB come wif sensors???...if not, which sensor would fit the TB???...ITR TB sensors???...B16 TB sensors???
Old Aug 16, 2005 | 06:43 PM
na200whp's Avatar
Default Re: (cyrix12)
any honda tps will work
Old Aug 16, 2005 | 08:20 PM
^^ right you are. Just has to be re-calibrated and you're good to go.
Old Aug 16, 2005 | 10:13 PM
ANR008's Avatar
Default Re: (jd3jdm)
rpm service offers many sizes from 68mm all the way up to 74mm that will bolt up using your stock honda tps
Old Aug 16, 2005 | 11:01 PM
CRVTEC0WNZJ00's Avatar
Default Re: (ANR008)
I'm using a STR 70mm TB port matched to an AEBS Manifold, and just threw on a SiR2 92-95 EG TPS which makes since since I'm putting it in my 93 Si look into STR or ericks racing if you want.
Old Aug 16, 2005 | 11:11 PM
DOMKID's Avatar
Default Re: (CRVTEC0WNZJ00)
I like the RPM service unit. My friend installed it on his motor, works great. Nice craftmanship.
Old Aug 16, 2005 | 11:56 PM
cyrix12's Avatar
hi bro....thks for you rreply....how abt MAPs??
Old Aug 17, 2005 | 10:10 AM
Snail EG's Avatar
map sensor will also bolt right onto an rpm service throttle body
Danial
Jul 10, 2012 02:34 PM
unusual71
11
Jan 20, 2010 09:01 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
Adi Radoncic
Apr 29, 2005 05:21 PM
Andre
Oct 25, 2004 03:18 AM
