fuel pressure on gsr
Mine is at 43psi at idle
I did a search on google and got this link...
http://www.geocities.com/~turbotage/...gra_specs.html
Do yourself a favor... go to a dyno where they also have air/fuel sensor... Have them tune that also... If you are going to someone who will be advacing the timing/cams and not messing with the fuel, it's no good... If you need one that isn't to far from you (St. Pete), I know an awsome tuner that I use all the time.
If you would rather get your car completely tuned for the cash you're going to spend, then lemme know....
