oil in spark plug tub
Old Aug 13, 2005 | 07:33 PM
accordredliner's Avatar
* B A N N E D *
Default oil in spark plug tub
I read that I need to change some kind of oring that is under the rocker arm asy. What exactly will I be looking for and is take off the rock arm asy straightfoward?
Old Aug 13, 2005 | 08:14 PM
BLKFLSH's Avatar
Default Re: oil in spark plug tub (accordredliner)
Do you have a repair manual? You have to back off valves before removing rocker arms. need information to torque, set valves ect. For me setting valves was hardest part seems like you need three hands. My manual went with car when I sold it. Not a very hard job if you can read and follow directions in manual.
Old Aug 13, 2005 | 08:39 PM
deserthonda's Avatar
if u are seeing oil when u remove spark plug wires the first thing i would do is replace the spark plug seals they are under the valve cover ,,,,,,,,remove valve cover turn it over there are 4 oval shaped seals . replace those, install new valve cover gasket. put a light film of honda bond on plug seals and at the curved ends in valve cover gasket put it together ,,see if it will fix ur problem
Old Aug 13, 2005 | 09:41 PM
cottonfamily05's Avatar
Default Re: oil in spark plug tub (deserthonda)
I have same problem...getting the silicone rubberish gaskets. is Honda bond still needed? My valve cover is leaking bad as well.
Old Aug 14, 2005 | 07:02 AM
Default Re: oil in spark plug tub (ejc3110)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejc3110 &raquo;</TD></TR><TR><TD CLASS="quote">I have same problem...getting the silicone rubberish gaskets. is Honda bond still needed? My valve cover is leaking bad as well.</TD></TR></TABLE>
replace the valve cover the reddish rtv silicone should work ok ,,jst do not use too much of it and put it only at the end of valve cover at the arches
Old Aug 14, 2005 | 09:02 AM
* B A N N E D *
Default Re: oil in spark plug tub (BLKFLSH)
what do you mean by backing off the vavle?
Old Aug 14, 2005 | 01:25 PM
NAiL05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">
replace the valve cover the reddish rtv silicone should work ok ,,jst do not use too much of it and put it only at the end of valve cover at the arches </TD></TR></TABLE>
Just ask for a Valve Cover Gasket at the local Advance Auto and they will give you a whole kit. They will give you the main gasket and the 4 tube seals. And apply the silicone where deserthonda said.
Old Aug 14, 2005 | 05:04 PM
* B A N N E D *
i tried the replacing the four gasket already. it didn't fix the problem. The valve cover gasket is not leaking btw.
Old Aug 14, 2005 | 05:26 PM
BLKFLSH's Avatar
Default Re: (accordredliner)
The manual sayes to back off the valves before removing rocker arm assy. I guess so there is no tension on valves when tourqing back down. Then you have to reset valves after. The engine has to be turned with a ratchet on the crankshaft bolt to set each valve. I would send you a copy of the proceedure, but I gave my repair manual to the person who bought my 92. Maybe DesertHonda can help with the process?
Get a repair manual (the one from honda dealer Helms I think), if you have common sense and can read and follow directions it can save you a lot of money. It saved me a lot.
Modified by BLKFLSH at 6:40 PM 8/14/2005
Modified by BLKFLSH at 6:41 PM 8/14/2005
Modified by BLKFLSH at 6:58 PM 8/14/2005
Old Aug 14, 2005 | 09:47 PM
* B A N N E D *
I have the manual. I just need some additional info to supplement the manual. It can be confusing sometime.
Old Aug 15, 2005 | 03:35 PM
BLKFLSH's Avatar
If you have the o-rings.
1. remove valve cover
2. loosen jam nut on valve adjusting screw
3.back off valve adjusting screws on all valves
4.loosen rocker arm assy bolts (I would loosen each one one half turn at a time until they can be turned by hand). leave the bolts in the rockerarm assy so you don't mix them up
5. If I remember right, you can lift up rocker arm assy. and not lift or move the cam if you watch what you are doing. The side opposite the timing belt may want to come up because the belt is pulling the other end down.
6.replace o-rings from around sparkplug holes. (read manual please)
7.replace rockerarm assy. and torque bolts down. (read manual please, for sequence and ftlbs.)
8.set valves,( read manual for settings and proceedure), you have to turn the engine over with a ratchet on the crankshaft bolt for each set of valves.(If the crankshaft is hard to turn, you can remove sparkplugs to make it easier to turn)
9.relpace valve cover (REMEMBER THE TOURQE ON THE VALVE COVER NUTS IS ONLY 7FTLBS), sparkplugs, and wires, (DON'T FORGET TO INSTALL THE GROUND WIRE TO THE VALVE COVER) IF THERE IS ONE .
GOOD LUCK !!!
YOU NEED TO FOLLOW THE PROCESS IN THE MANUAL, TAKE YOUR TIME AND DO IT RIGHT OR YOU WILL SCREW SOMETHING UP. FOR YOUR OWN SAKE DON'T BE IN A HURRY TO FINISH THE JOB. YOU SHOULD ALSO HAVE SOME HONDABOND GASKET SEALANT ON HAND TO DO THE JOB RIGHT.NOTHING GOES THROUGH HONDABOND!!!
Modified by BLKFLSH at 4:48 PM 8/15/2005
Old Aug 15, 2005 | 04:01 PM
turboedd15b's Avatar
Use OEM Honda Parts for all parts on car,Dont use cheap aftermarket.
FOR SALE******** 91 Honda Accord H22 Type-S swap 2 door coupe bronze color,black rota slips, Apexi WS exhaust, full MSD Ignition, Jun ECU, skunk 2 coilover package, sway bars, Sparco seat with harness, JDM front end conversion very clean garage kept 16K on engine. Royal Purple Oil changed every 1000 miles. 13.26 @103.5 mph $5500.00 Please call Matt 804-437-3386 Please serious inquirys only Email for pics
Old Aug 15, 2005 | 09:38 PM
* B A N N E D *
I read my haynes manual and it saids to take off the timing belt before the rocker arm. Mistake?
Old Aug 16, 2005 | 03:21 AM
BLKFLSH's Avatar
That's because it is based on a complete teardown and rebuild of the entire engine. That's why the Helms manual is better for specific jobs. It's easier to follow. If your going to teardown the entire engine, It would make sense to do that first. The engine would have also been removed from the car by then.
Modified by BLKFLSH at 6:21 PM 8/16/2005
Modified by BLKFLSH at 4:34 AM 8/17/2005
Old Aug 19, 2005 | 03:13 AM
BLKFLSH's Avatar
Default Re: (BLKFLSH)
Are you going to give it a shot, or seek professional help. How did it go?
Old Aug 19, 2005 | 04:41 AM
YeuEmMaiMai's Avatar
I am having Huey's do it for me total cost including valve adjustment and valve cover and sparkplug tube seals is about $150
Old Aug 19, 2005 | 01:06 PM
BLKFLSH's Avatar
Default Re: (YeuEmMaiMai)
Good deal man. They usually charge 90 or so bucks just to set the valves.
Old Aug 19, 2005 | 08:13 PM
what if u just replace the seals and not set the valves? what is going to happen?
Old Aug 19, 2005 | 08:53 PM
sauceja's Avatar
Default Re: (ejc3110)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejc3110 &raquo;</TD></TR><TR><TD CLASS="quote">what if u just replace the seals and not set the valves? what is going to happen? </TD></TR></TABLE>
You will risk your valves slapping the piston at an inapropriate time and F*C* something up. Or your valve openings are going to be all screwed up and you will think you are in a blown 454 at the tree.
HONDABOND RULES!!!!!!!
Old Aug 19, 2005 | 09:12 PM
Huey's is a good place here in st louis. I wanted a valve adjustment and they stated that it was preferable to change the seals at the same time (gasket and plug seals since they had to remove the valve cover to get to the valves. it added $40 to the price so I said why not?
Old Aug 20, 2005 | 11:56 AM
* B A N N E D *
i'm gonna wait until i'm out of school. Thanks for the tips though. If I can do Tming belt and I probably do this
Old Aug 20, 2005 | 05:19 PM
BLKFLSH's Avatar
If it starts leaking too bad, the oil can start shorting out the spark plug. This will make it run real bad. Then you have to find a way to suck it out of the tube. If you can't suck it out with the sparkplug in the tube, when you remove the plug all that oil is going into the cylinder. Don't wait too long, or find a way to get it out without removing the plug. I duck taped a small hose to a little shop vac and sucked as much out as I could with the plug still in the engine. Just something that might come up later, if you have to wait a while to get it done. If you have a little vacume pump that would be even easier.
Modified by BLKFLSH at 6:13 AM 8/21/2005
Old Aug 21, 2005 | 02:41 PM
sauceja's Avatar
You can also spray some brake cleaner in there and use compressed air and a couple of shop towel to cover and soak it up when it is sprayed out. You may have to do this a couple of times.
Sucking it out is better but if you can't. Make sure plug is still in when you do this.
Old Sep 7, 2005 | 08:35 PM
* B A N N E D *
Ok I just read my Haynes and Factory Manual and it doesn't say anything about setting the valves. Are you sure that you have to set the valves?
Old Sep 7, 2005 | 08:39 PM
LOGICx420x's Avatar
Had the same problem, change your seals,,,,,
