CRX custom turbo kit pics
Old Aug 13, 2005 | 07:25 PM
tony1's Avatar
Default CRX custom turbo kit pics
Here's some pics of a custom turbo kit I've been working on at the shop. The motor is a B20/Vtec and the car is being built for the street tire class. We'll see how it dynos in a couple weeks. The customer really did his homework and picked out some nice parts. Anyways, here's some pics...
Old Aug 13, 2005 | 07:39 PM
The Destroyer's Avatar
Default Re: CRX custom turbo kit pics (tony1)
I want to learn how to do **** like that so bad.
Old Aug 13, 2005 | 07:43 PM
Darin D.'s Avatar
Nice work Tony! Shop looks great as well.
Old Aug 13, 2005 | 07:51 PM
adictionbass's Avatar
Default Re: CRX custom turbo kit pics (Darin D.)
yea, that looks pretty sick tony. lets gets some numbers
Old Aug 13, 2005 | 08:28 PM
speeddave's Avatar
Default Re: CRX custom turbo kit pics (adictionbass)
looks great! what turbo is he running?
Old Aug 13, 2005 | 10:54 PM
sporkcrx's Avatar
Default Re: CRX custom turbo kit pics (speeddave)
That shop is filthy!
Old Aug 13, 2005 | 11:38 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: CRX custom turbo kit pics (sporkcrx)
Looks good but i'm getting a bad vibe off the downpipe....
Old Aug 14, 2005 | 01:39 AM
ChainbreakR's Avatar
Default Re: CRX custom turbo kit pics (2000psi)
That downpipe is amazing! Your welds all looks soo nice...
Old Aug 14, 2005 | 04:02 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: CRX custom turbo kit pics (ChainbreakR)
Wild! i LIKE the downpipe!
T1
Old Aug 14, 2005 | 05:14 AM
Danger's Avatar
as usual , nice fab work
Old Aug 14, 2005 | 08:50 AM
tony1's Avatar
The downpipe is what the customer wanted, to keep it quiet on the street yet have the performance potential of an open downpipe. Priority of flow was given for the open downpipe. It also comes off at the first v-band and the rear flange and another piece goes in with a cat for inspections. The turbo is a T4 60-1. In test driving it, it's making 5psi by 2500rpms with the exhaust cutout closed, so running through 2.5" crush bent exhaust.
Thanks everyone for the comments. Here's some more pics of the shop, before and after. I need to take some more recent ones, as I've done quite a bit more since these pics.
Old Aug 14, 2005 | 08:56 AM
Danger's Avatar
damn those pics are huge ! shop looks nice , what material did you use to paint the floor ?
Old Aug 14, 2005 | 08:59 AM
SL0WEGG's Avatar
nice work
Old Aug 14, 2005 | 09:05 AM
tony1's Avatar
Default Re: CRX custom turbo kit pics (MrDanger)
Sorry, i'm lazy, didn't feel like resizing the pics.
The floor is an epoxy coating from Sherwin Williams. It really makes the shop easy to clean, spills wipe right up and don't soak into the concrete anymore. Those pics kinda suck, i'll get some new ones next week.
Old Aug 14, 2005 | 09:29 AM
B20TDC2's Avatar
always nice work tony
shop looks good
Old Aug 14, 2005 | 10:35 AM
ineedhelp's Avatar
looks really good. i like the custom precision intercooler a lot, any other close up shots of it? what material did you us for the end tanks?
Old Aug 14, 2005 | 10:53 AM
tony1's Avatar
Default Re: CRX custom turbo kit pics (ineedhelp)
The end tanks are the standard precision cast tanks from the 750hp core, but notched and welded on to fit between the oem framerails. The tubing welded on is 16ga (.065") aluminum and the tank is a good .200" or so cast.
Old Aug 14, 2005 | 11:00 AM
ineedhelp's Avatar
so would welding cast aluminum to the aluminum tube be any differnt then welding two aluminum tubing together?
Old Aug 14, 2005 | 11:01 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
clean!!..and the shop looks great...get those updated pics up!!
Old Aug 14, 2005 | 11:05 AM
tony1's Avatar
Alot of times cast doesn't weld as good as a good piece of 6061. Depends alot on the quality of the casting. The only thing big thing different than welding 2 tubes together is focusing the heat right since you have one piece .065" thick and one 3 times that.
Old Aug 14, 2005 | 11:42 AM
mtber's Avatar
Nice work
Old Aug 14, 2005 | 01:07 PM
speeddave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">The downpipe is what the customer wanted, to keep it quiet on the street yet have the performance potential of an open downpipe. Priority of flow was given for the open downpipe. It also comes off at the first v-band and the rear flange and another piece goes in with a cat for inspections. The turbo is a T4 60-1. In test driving it, it's making 5psi by 2500rpms with the exhaust cutout closed, so running through 2.5" crush bent exhaust. </TD></TR></TABLE>
i look forward to seeing the power figures produced, i'm thinking of using the same turbo for my ls/vtec
Old Aug 14, 2005 | 03:56 PM
Kevin's Avatar
Looks very well thought out.
Old Aug 14, 2005 | 04:03 PM
DaveF's Avatar
Default Re: CRX custom turbo kit pics (gLok)
WOW, that new shop is VERY NICE
im in a predicament with my crx/750 intercooler install as well, at first i was gonna make a whole new end tank, but i might do something like this, seems alot easier. that car is real nice
Old Aug 14, 2005 | 05:16 PM
Full-Race Javier's Avatar
nice
