Brake Problem after Steel line
Old Aug 13, 2005 | 06:33 PM
SoneCorDC2's Avatar
Default Brake Problem after Steel line
Hi I'm new to the forum and need help... here goes..... Okay me and a buddy of mine we just changed my stock brake lines to Earl's Steel Brake line... make story short after we change it out we bleeded the brakes and No brakes still so we check for leaks no leaks..so we assume it was the M/C or Boot... so we changed out the M/C and now i have brakes again..but i don't know if its in my head or my brakes feel some what weak from stock.... called a Local shop..they say it'll take about a day or 2 of driving before i get the full brake pressure.... is that true? or should i go back on checking for leaks?
Old Aug 13, 2005 | 06:43 PM
gsrboi80's Avatar
Default Re: Brake Problem after Steel line (SoneCorDC2)
sounds like you have some air in there try bleeding them all out agian
Old Aug 13, 2005 | 06:48 PM
SoneCorDC2's Avatar
Default Re: Brake Problem after Steel line (gsrboi80)
again...dang... its a lot of work to bleed .... oh well.. i guess i'll try it again and see what
happends... thanks... oh by the way is there an easier way of bleeding the brakes other than jacking all four wheel up and taking four wheels off and bleeding them one by one??? and shortcut??
Old Aug 13, 2005 | 08:23 PM
gsrboi80's Avatar
nope one by one is the only way I know. They say to rotate around the car.
Old Aug 13, 2005 | 08:48 PM
txracer's Avatar
isnt there power brake bleeders or vaccum brake bleeders?
Old Aug 13, 2005 | 11:08 PM
kandyflip445's Avatar
Default Re: Brake Problem after Steel line (txracer)
Yes there are tools you can use.
http://www.eastwoodco.com/shop...=2371
http://www.eastwoodco.com/shop...12531
http://www.sears.com/sr/javasr...Tools
http://buy1.snapon.com/catalog...talog
http://www.harborfreight.com/c...37201
Sorry if that's too many links. There are more out there, just search.
Did you make sure to bench bleed the MC first? You can also buy speed bleeders.
http://www.speedbleeder.com/
The part number is SB10125 for front and back calipers on all Integras 90'-97'.
Good luck.
Old Aug 14, 2005 | 01:43 AM
SoneCorDC2's Avatar
Default Re: Brake Problem after Steel line (kandyflip445)
You guys are awesome...thanks for the reply.....
tommyofyork
Apr 8, 2007 05:45 PM
JDM_EK_JOE
Apr 14, 2006 11:44 PM
benson03
Feb 20, 2006 09:05 AM
mickey513
Dec 2, 2003 07:53 AM
GQ Cowboy
Jul 25, 2002 06:06 AM
