loose caliper pin
Old Aug 13, 2005 | 05:00 PM
Silvteg95's Avatar
Default loose caliper pin
I have a knocking sound whenever i go over a bump or even sometimes just on flat road, the caliper pin has a little play in it, is it htis thats making the sound, everything else suspension wise seems to be fine
Old Aug 13, 2005 | 09:22 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: loose caliper pin (Silvteg95)
free bump
Old Aug 13, 2005 | 10:51 PM
kandyflip445's Avatar
If you have a service manual you could try to torque everything in the suspension to spec. Also, lube everything up in the suspension. Next you could make sure you have the lug nuts torqued also. On 240's if lowering springs aren't put on the damper right then it can move around and make those sounds. If it's the same on Integras check that out also. Make sure all bushings are intact.
Good luck.
scottbedard
Suspension & Brakes
Apr 19, 2010 02:34 AM
01 itr dc2
Suspension & Brakes
Jun 4, 2007 02:30 PM
teggytegteg
Jul 8, 2004 01:04 PM
nugget8000
Jan 22, 2002 01:13 PM
