97 accord running hot
Old Aug 13, 2005 | 01:05 PM
ranger714's Avatar
Default 97 accord running hot
Read the archives,where is the location of the thermostat? And any other ideas,you shouldnt have to run the heater in the summer to keep your car cool!
Old Aug 13, 2005 | 01:14 PM
hondadude's Avatar
Default Re: 97 accord running hot (ranger714)
Follow the lower radiator hose to the T-stat housing. Be sure the block is full of coolant and burp the block thru the 12mm bleed screw at the T-stat housing. When the car is around 1/2 temp on the gauge you should hear the cooling fans cycle.
Old Aug 13, 2005 | 01:29 PM
ranger714's Avatar
thanks for the location information.
Old Aug 14, 2005 | 09:33 AM
ranger714's Avatar
Default Re: (ranger714)
thanx for the information on the location of the thermostat, put a new one in and now the problem is solved i don't have to run around blazing the heater in this blazing heat THANKS!!!!!
VERGOTEx3
Jul 9, 2010 01:39 PM
505hightek
Jun 28, 2010 06:24 PM
NiPpZ
Apr 21, 2010 08:41 PM
tom48
Oct 22, 2009 09:25 PM
abaaj
Feb 22, 2005 04:54 PM
