Tech drosp to Zero when I press the gas pedal
Old Feb 22, 2002 | 06:23 AM
mattymatt's Avatar
New User
Default Tach drops to Zero when I press the gas pedal
I've done a search on this, but the best I could come up with was an ignitor problem, that I don't think I'm having...
Yesterday, I noticed that when the car's in neutral (at a stop light) and a press fairly hard on the brakes, my needle will drop from ~800rpm (idle) to flat out 0. As soon as I let go, it jumps back to ~800rpm. The engine sounds fine, its just the tach that bounces.
However, the problem went away later in the day... in case it happens again, what could be causing this?
[Modified by mattymatt, 3:23 PM 2/22/2002]
Old Feb 22, 2002 | 06:24 AM
mattymatt's Avatar
New User
Default Re: Tach drops to Zero when I press the gas pedal (mattymatt)
<edit> Geeez, I can't spell. I meant "Tach drops to zero"
Old Feb 22, 2002 | 08:07 AM
owen_the_soyboy's Avatar
same **** happened to me in my civic.
I had a bad ground connection at the main fuse relay near the battery.
these symptoms may be the sign of a poor charging electrical system or a major problem about to happen. have it checked out by a trusted mechanic or do some basic investigating on your own.
have you recently modded your car in any way that included playing with the electrical system????
Old Feb 22, 2002 | 10:40 AM
mattymatt's Avatar
New User
Default Re: Tach drops to Zero when I press the gas pedal (owen_the_soyboy)
Thanks for the reply. No, I haven't touched the electrical system at all. I seriously hope its not going to cause major problems, because I can't afford it right now!!!
CivicNoVa
Jun 23, 2011 03:37 PM
92integracer
Oct 8, 2008 09:19 PM
Nihilus
Dec 18, 2005 01:28 AM
Chronicsinners
Mar 4, 2005 08:23 AM
rdiggidy
Aug 17, 2004 05:16 PM
