clutch release noise. help!
yo, sometimes when i release the clutch pedal into 1st 2nd and rarely in 3rd, I hear a wierd belt slipping type sound. it happens i think more when it's wet out. I would be more worried about it if it happend all the time. but it happens right as it's being engaged and if i keep my foot right at the point where the noise happens, the noise will drag out for a while. sounds shitty, but it works fine I'm just getting embarrassed at stop lights and going slow up hill.
eg, gsr engine, 98 JDM ITR trans w/ lsd, spoon 3 puck clutch and flywheel
Remove your accessory belts just to diagnose for one trip around the block.
ex Samurai Warrior, 374 AW, Yokota AB, Tokyo Japan
1995 ~ 2003
still living here though.
1995 ~ 2003
Do you mean i should check the tension or like for checking the pully berrings and stuff cuz it's not my belts, it just sounds like a belt slip?
idriveadelsol7
Aug 26, 2005 04:35 AM
fire7882
Nov 21, 2003 05:21 PM
