something is draining my battery
Old Aug 12, 2005 | 07:24 PM
SiMateoAko's Avatar
Default something is draining my battery
I recently installed a bulldog keyless entry into my 1989 Civic LX. It works like a charm... until my battery started dieing. I first thought it HAD to be the keyless entry as I had made no other changes.
Until today.
I bought a multimeter and started testing. Looks like there is a .65A drain on my battery. This means it takes a long time to drain the battery, but it still does none the less. I pulled one fuse at a time and checked the battery. With each fused pulled, .65 still read at the Amps being used.
I can't figure it out.
Should I also pull the fuses under the hood and try the same thing? Does anyone here have any ideas as to what could be causing this to happen?
lemonfresh
Sep 7, 2012 01:42 PM
Turbo_Mike
Apr 30, 2006 06:25 AM
crxh22project
19
Mar 23, 2005 08:19 AM
barefootbilly
14
May 25, 2004 06:32 AM
d8168055
Audio / Security / Video
Nov 10, 2002 03:15 PM
