wiring ?'s
I am trying to find out, on the 8-pin connector next to the resistor box on a 90 si hatchback, what does the black with yellow stripe wire run, and the solid blue wire run to. I need to find out, cause my car wont start, and these are the only 2 wires disconnected at this time.
I had to re-pin the connector, cause I have an 88 si underdash harness, and a 90 si engine harness. The 88 has a 6 pin connector, and the 90 has an 8 pin connector. The wires I am looking for, is a black wire with a yellow stripe, and a solid blue wire.
Lets all take a look at what this A-hole just emailed me!!!
Here is what I emailed in responce from him asking me this question again via email...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi from email »</TD></TR><TR><TD CLASS="quote">"I allready told you on H-T. Those are for the fast idle valve on the 89-91 civic/crx si. Make sure the rest of the pins match on the other plugs, they
> prolly dont.</TD></TR></TABLE>
And what this dood has the nerve to say back!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracer197791 from email »</TD></TR><TR><TD CLASS="quote">well, sorry to say to you, but you must not know
much about wiring. Look at
the distributor wiring, then go look at the
distributor wiring diagrams. The
distributor has those colored wires. Why would the
fast idle valve not being
hooked up cause a no spark problem. The wiring
diagrams show that the blue
wire is the tach signal, and the black wire with
yellow stripe goes into the
igniter unit, and it exits with a white wire to the
ECU. Apparently you are
no hot **** at wiring, like you think you are. I
just thought you might
know, because so many people were referring you.</TD></TR></TABLE>
OK, he is right about the coil wire, and the tach signal being those colors. BUT Those are for the fast idle (page 670 of crx worshop manual) valve. He sent me a pic of the 2 mystery wires here...
As you can see that is the drivers side plug and the 2 extra wires ARE the fast idle valve.
And for mr. Hondaracer197791 please never ask me for help ever again!! Sometimes I wonder why I help people here on h-t...
Ryan (rywie)
Ryan (rywie)
CRX workshop manual page 670.
yeah droppedcrxsi doesnt know anything about wiring, lol are you ******* serious, u must not be on here much i guess or something i wouldnt trust anyone but him for wiring on here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote">hey nikozai where can i find diagrams like that need them bad</TD></TR></TABLE>
Lizardslap
20
Jan 9, 2023 04:43 PM
prelude182
Feb 24, 2011 11:23 AM
Jakester9500
Mar 6, 2007 03:21 PM
I8ayellowcrayon
May 24, 2004 08:21 PM
