Anyone Run Rocket Motorsports M22's in a LS Vtec?
Old Aug 12, 2005 | 04:14 PM
sik civic's Avatar
Default Anyone Run Rocket Motorsports M22's in a LS Vtec?
At the present I'm runing B16A second Gen Cams, Springs and Retainers in my LS Vtec.
I'm running 11.3:1 Compression and have just purchased RM M22's with their Gen 2 Titanium Springs and Retainers.
I can't wait to see that kind of power we find with hondata after I throw all these goodies in.
Old Aug 12, 2005 | 04:23 PM
Rocket's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (sik civic)
Here's a clip of an LSVTEC with M22's
http://www.sfu.ca/~bbwu/doulik/successvtec.mpg
Old Aug 12, 2005 | 04:26 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic &raquo;</TD></TR><TR><TD CLASS="quote">At the present I'm runing B16A second Gen Cams, Springs and Retainers in my LS Vtec.
I can't wait to see that kind of power we find with hondata after I throw all these goodies in.</TD></TR></TABLE>
They should do quite well.
Old Aug 12, 2005 | 04:28 PM
sik civic's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (Rocket)
Wow!
Old Aug 12, 2005 | 04:38 PM
Rocket's Avatar
Most stage 2 cams will work well. I am a firm believer in good head work. Contact RLZ Engineering (MAX_CFM here). He's the king of head porters here.
The car in the vid had a head prepared by me with an excellent valve job. The motor even made good power with GSR cams.
Old Aug 12, 2005 | 04:46 PM
itralex's Avatar
btw, Rocket Forgot to mention that motor was running STOCK b16 header with STOCK LS exhaust and Intake
btw, those m22's in that video are in a 85mm bore 12.6:1cr Motor now
Old Aug 12, 2005 | 04:51 PM
sik civic's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (itralex)
Holy crap!
Old Aug 12, 2005 | 08:02 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Just make sure you have good parts and tuning to go along with it, and you should see great results.
Old Aug 13, 2005 | 03:17 AM
sik civic's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (rochesterricer)
I didn't want to bore you guys with the full details, but I've rebuilt the bottom end and upgraded a few things. All the usual things that should be done on an LS Vtec have been done, I have not gotten a valve job or had it port and polished. $$$$
However. Adjustable cam gears are something I'm looking into before I throw these M22's in. Is that a good idea, or can my tuner make those adjustments through Hondata tuning?
Old Aug 13, 2005 | 04:33 AM
UNKNOWN_MEMBER's Avatar
anymore videos of cars running m22s? and was the ls/vtec tuned in the video?
Old Aug 13, 2005 | 11:26 AM
Rocket's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (UNKNOWN_MEMBER)
Car was running a basemap I wrote.
Old Aug 13, 2005 | 11:27 AM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">btw, Rocket Forgot to mention that motor was running STOCK b16 header with STOCK LS exhaust and Intake
btw, those m22's in that video are in a 85mm bore 12.6:1cr Motor now</TD></TR></TABLE>
for Canadians.
Old Aug 13, 2005 | 11:28 AM
Rocket's Avatar
Cam gears are always reccomended to adjust for head and deck height.
Old Aug 13, 2005 | 11:47 AM
LSVTEC 91 Civic's Avatar
Banned
I've been looking for a good LSVTEC cam, I only made 190whp with a set of billet webs and around 12.3:1 comp... Information on my motor is under my bio in my profile..
Old Aug 13, 2005 | 12:48 PM
VtecKiDD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">anymore videos of cars running m22s? and was the ls/vtec tuned in the video?</TD></TR></TABLE>
My M22/ANR GSR CRX vs ITR EF hatch with Toda Cs and Hytech header
http://www.hondalife.com/~chun...r.wmv
My M22/ANR GSR CRX vs RSX-S with 210whp
http://www.hondalife.com/~chun...y.wmv
My M22/ANR GSR CRX on the Dyno
http://www.georgiaboost.com/mo...o.mov
Old Aug 13, 2005 | 01:04 PM
Hybrid96EK's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (VtecKiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.georgiaboost.com/mo...o.mov</TD></TR></TABLE>
Looks like th EF had you beat. In the second race it appears that you just kept going after he quit.
The RSX run was rather strange too. In the first run, you are fairly even, then you missed a gear.. The "middle" runs you clearly were able to pull on him, then in the last run it looks more along the lines of what I thought the first race would be.
The dyno video showed us nothing.
More details on your setup please. What were the final dyno number also?
Old Aug 13, 2005 | 01:20 PM
VtecKiDD's Avatar
Default Re: Anyone Run Rocket Motorsports M22's in a LS Vtec? (Hybrid93Eg)
first run against the EF was from LOW mph, he has a 4.9 fd. if you watch Closely you can see he pulls initially, then i start to reel him back in before a car pulls out in front of us.
second run, that was all the way at full throttle, i puled hard on him in the top end.
RSX we were dead even on the first pull, then i mishifted. the rest i walk him pretty easily.
Dyno was just me doing a 9700rpm pull
Old Aug 13, 2005 | 01:36 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 13, 2005 | 01:52 PM
VtecKiDD's Avatar
Block:
B18C1 Gsr Block 81.5mm
B16 Pistons PR3
GSR rods Blanced with ARP 2000Series Rod Bolts
ARP Headstuds
OEM 3 LAyer Headgasket
Crank balanced, pistons Balanced
ACL Bearings
decked .010
11.5:1 compression
Head:
B16 Head 1st Gen Unported, stock valves
Rocket Motorsports M22s
Rocket Motorsports Valvetrain and Retainers
AEBS intake Manifold (Lightly ported by Rocket)
ANR Compact Header with Merge Collector
H22 290cc injectors
B+M FPR
All tuning was OBD0 with a VAFC and Rocket Motorsports ECU Chip. never knew what my timing was at. I was also dropping 12psi in FP in vtec Xover cause my pump failed
I made consistent 187whp, once i made 191whp. Dynojet
not bad for a stock unported head
Old Aug 14, 2005 | 03:43 PM
sik civic's Avatar
My thread got jacket, kindda!
But is a GSR Block With GSR Crank and Rods Plus a B16A Head really considered an LS Vtec?
Old Aug 14, 2005 | 03:56 PM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic &raquo;</TD></TR><TR><TD CLASS="quote">My thread got jacket, kindda!
errr.....that would be a GSR motor
LS/vtec is a block with a LS crank and Vtec head
Old Aug 14, 2005 | 04:11 PM
sik civic's Avatar
OK wow, you must think I'm as stupid as most everyone else.
That was a retorical post to draw attention to something else.
VtecKiDD gave his specs on his engine, and I thought this was a LS Vtec related post, but now I realize he uses M22's and that's where his info fits in.
Old Aug 14, 2005 | 04:27 PM
VtecKiDD's Avatar
a guy asked me to post Videos of cars with M22s, so i did.
i have 2 m22s in LSVTECs out here, ill see if i can get video of them.
I also have a LSVTEC 2.0 motor im building now that im using M24x's in
Old Aug 14, 2005 | 05:16 PM
sik civic's Avatar
No disrespect, just trying to deflect the foolishness.
Very nice. Well you've got a few builds on me!
So I guess your a fan of RM then eh?
I'm going to just throw them in my B16A tomorrow evening, I'll let you know what the results are.
Old Aug 14, 2005 | 05:21 PM
VtecKiDD's Avatar
keep me posted, i have a b16 locally that i built with M22s, AEBS manifold, DC JDM 4-1 header , omnipower valves. stock block stock unported head, makes 170whp
