Superglue on car paint.
Old Aug 12, 2005 | 02:28 PM
thatonejewishguy's Avatar
Default Superglue on car paint.
How would I get some superglue that accidently got onto my car off?
Old Aug 12, 2005 | 02:33 PM
alotawatts's Avatar
Default Re: Superglue on car paint. (thatonejewishguy)
Heat will loosen superglue so park it in the sun or use a hot hair dryer and naptha (lighter fluid) or acetone...............well ....be carefull with the acetone.
Old Aug 12, 2005 | 02:40 PM
gaydm.accord's Avatar
Default Re: Superglue on car paint. (alotawatts)
really really really really fine sand paper and take your time. then polish and buff.
Old Aug 12, 2005 | 03:19 PM
Default Re: Superglue on car paint. (gaydm.accord)
i hope you're kidding i'm not gonna sand my car
Old Aug 12, 2005 | 04:07 PM
Botle Rocket War's Avatar
Acetone will dissolve it, but very slowly. I am not sure what acetone will do to a paint surface, but I doubt it will hurt. Try it under the trunk lid first and see if anything happens...Let it sit for a while. Make sure after you get it off, regardless of what you use, that you re-wax the area.
Sanding (wet sanding) is fairly common in car detailing with 4,000 grit sand paper, but is definitely not the solution to this problem.
Old Aug 12, 2005 | 04:35 PM
YeuEmMaiMai's Avatar
sand and add a layer of clear coat. it is really easy to paint. just take your time and practice first
Old Aug 12, 2005 | 07:54 PM
P_Adams's Avatar
Hobbiests who use Superglue in constructing Remote Piloted Vehicles (R/C) have for years been using a product which removes excess Superglue from stuck fingers and other unspecified body parts. It's called a debonder and it's marketed by several US companies. It's available at most local hobby shops.
Test anything you may use first on a hidden panel
P
Old Aug 13, 2005 | 12:38 PM
STREETWERKZ's Avatar
Default Re: Superglue on car paint. (P_Adams)
you got superglue on your paint, but are worried to use fine sand paper then buff and polish?
Old Aug 13, 2005 | 02:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Hobbiests who use Superglue in constructing Remote Piloted Vehicles (R/C) have for years been using a product which removes excess Superglue from stuck fingers and other unspecified body parts. It's called a debonder and it's marketed by several US companies. It's available at most local hobby shops.
P</TD></TR></TABLE>
I am a "hobbiest". I fly radio control aircraft and have the debonder that you speak of. It's about $2 at a hobbdy store...I guess if you don't have acetone or something like that around (most people don't) the debonder is the cheapest thing to buy. I should have thought of that!
Project_EK
Mar 1, 2005 06:26 PM
FBP Si 2000
Mar 3, 2003 07:46 PM
doobiesack23
Jan 16, 2003 11:35 AM
zseeanz
11
Dec 13, 2002 08:59 PM
cracker099
Nov 30, 2002 11:14 PM
