Center Clock light
99 Accord LX. Is it normal for my center clock light to burn out every few months? I'm already on my 3rd light, and while it doesnt cost me much at 57 cents a pop.. i'm just pissed i have to keep doing it when i havent been in any accidents or hard jolts to screw it up. U think my subwoofer has something to do with it? Anybody else have this prob?
I wouldn't think your subwoofer has anything to do with it because it's all the way in the trunk.....but yeah, 3x does seem highly unreasonable for a clock bulb. Mine's out too.
Yep, it's a real problem. You shouldn't feel lonesome or pregnant. LOL
Be thankful you have an Accord, because on the Odessey the dash has to be removed to replace the bulb....yet it pays the same flatrate. Go figure.
Another bulb problem in the accords is the 'dome' light bulb; if you use a generic bulb from the parts store the plastic housing will melt down. The honda bulb is less wattage therefore less heat. Here's the kicker......Honda bulb is around $4.25 the generic bulbs are 2 for $1
Mr. Honda is probably turning in his grave over this engineering stupidity.
mine went out for the 3rd time on my 01 .. so i dont even bother replacing it anymore.. i heard some people would tap on it and it would come back on.. didnt work for me but its worth a try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuNDaY DRiVeR »</TD></TR><TR><TD CLASS="quote">Next time i passby an electronics store, i'ma buy a dozen or so of them annoying lil lights
IIRC it's a certain type that only auto parts stores (or even just the Honda dealer) might have. I have seen them on ebay...just type in "accord clock bulb" into your search parameters and it should pop up with at least 3 or more. HTH
</TD></TR></TABLE>IIRC it's a certain type that only auto parts stores (or even just the Honda dealer) might have. I have seen them on ebay...just type in "accord clock bulb" into your search parameters and it should pop up with at least 3 or more. HTH
Thanks so much for the info on LED type center clock lights.
11 years working at honda dealerships, 1 year working on 'euro imports', starting in on my 11th year working at a Honda independent.
Believe me my friend, if I wanted info on where to find a STOCK bulb, I just pick up a phone and say "get it here".
finally i decided to try an led light in there n man was dat a mistake.. the 1st one dat fit into the bracket thingy wouldnt work, so then i said **** it n tried a bigger blue led light n dat **** went up in flames as soon as i turned on ingition!
guess ima have 2 stick with my stereo time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_In_Japan »</TD></TR><TR><TD CLASS="quote">Just put an L.E.D. kit in it and call it good.</TD></TR></TABLE>
Works for me! Had mine in for almost a year now and no problems.
http://www.ledautomotive.com/O...o.asp
This guy works on eBay too, so I'm sure he'll make u a sweet deal on just the clock LED.
Works for me! Had mine in for almost a year now and no problems.http://www.ledautomotive.com/O...o.asp
sugarfree2121
Oct 31, 2017 12:59 PM
windriver10
Jun 11, 2010 11:51 AM
Terabass
Aug 20, 2007 08:24 PM
