Will JDM P73 pistons pass emission's
Old Feb 22, 2002 | 12:15 AM
underrated99si's Avatar
Default Will JDM P73 pistons pass emission's
Well I want to put them in and i know they raise compression to 11.1 so with stock cams and ECU and everything else stock will it pass or not.
Thanks in advance
CHRIS
Old Feb 22, 2002 | 04:21 AM
Mike K's Avatar
Default Re: Will JDM P73 pistons pass emission's (underrated99si)
just wondering.. why would you go through all that hassle just to raise compression half a point?
just shave the head or go thin headgasket.
i apologize if you don't drive an ITR. but if you do, it's a waste IMO.
oh, and you'll probably pass emissions w/ only a half point increase.
{edit} duh! I see your name has 99si in it. I didn't mean to come off rough on you. I'm assuming you're building a 1.8 block?
You know ITR pistons lower your compression in a B16 block, right?
[Modified by Mike K, 8:47 AM 2/22/2002]
Old Feb 22, 2002 | 11:51 AM
Default Re: Will JDM P73 pistons pass emission's (Mike K)
yes I know that ITR pistons will drop my compression to like 10.0.1 or so but I am putting a B18C5 in my SI and well i just want a little more compression and I like the sound of balanced and I can get them for under 3 bills so what the hell. Thanks for the feedback now I can order them and put them in along with the motor.
AssPenny
Jan 13, 2014 04:51 PM
_inline4turbo_
Apr 30, 2009 08:06 AM
PYITR821
Apr 6, 2004 12:50 AM
asianautica
Mar 26, 2003 09:49 AM
