80 shot on mostly stock F23
Well, I learned the hard way. I didn't get your post until it was too late. I ran the 80 shot on my car for some little here and there moments and melted my plug on #2. Now the car runs like S**t. I changed the plugs and wires out since the plug that melted messed up the wire. So where do I go next? Rotor button? Cap? Its missin pretty bad, almost sounds like a WRX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kvtecaccord »</TD></TR><TR><TD CLASS="quote">Why would that be a problem? And, what does that mean, meaning what am I checking for if the compression is off? Piston problems ?</TD></TR></TABLE>
You could've blown the rings. I've ran 50-75 shot and other than my plugs being a little black from being too rich I've never had a problem w/ my nitrous kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinker504 »</TD></TR><TR><TD CLASS="quote">No noise, but smoke is possible. Doing a compression check will assure nothing else is broken or damaged.</TD></TR></TABLE>
Smoke would be very likely if its rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kvtecaccord »</TD></TR><TR><TD CLASS="quote">Well, I learned the hard way. I didn't get your post until it was too late. I ran the 80 shot on my car for some little here and there moments and melted my plug on #2. Now the car runs like S**t. I changed the plugs and wires out since the plug that melted messed up the wire. So where do I go next? Rotor button? Cap? Its missin pretty bad, almost sounds like a WRX.</TD></TR></TABLE>
wow. that wasnt to smart! doh
i woudlnt think an 80 shot would have done much harm. what kinda of kit did you buy?
i mean, my understanding w/ a kit like, zex, its computer controlled and if your not getting enough gas an it runs lean, it'll shut off..and it adjust your timing.
am i wrong on this?
regardless..that sucks man.
but i am curious, what were your moments? like, how long were you on it? what were you doing?
elaborate a lil.
am i wrong on this?
elaborate a lil.
The kit was from my friend. It was one of those bottle in a bag kits. He ran it on his mostly stock Excort GT and sparyed the hell out of it and ran fine. It was a dry shot thru the intake and wasn't even a long shot, just here and there sprays. Still haven't done a compression test yet, not til thursday. Also, when I remove the plugs one at a time, all but one tries to stall when I remove it. When I pull the plug, there is absoluetly no change. When I pull the other wires off one at a time, the car wants to stall. Has to be a spark problem. Don't you think?
Oh and about the times I used it. I ran on I-95 runnin around 65-70 in 3rd and sprayed from like 70-90, didn't take long to get there, but that was about it. The bottle was full when I set it up and ended up only using about 10% of the bottle, so again, really didn't spray much at all. Kind of scared of the kit at first.
You would want to only run a 75 shot and with that you better keep a close eye on it with proper tuning. 75 shot is max on the f22 motor and even then your only going to get a year or two at the extreme max with regular use. On the f22's if you want longevity is to go 50 shot.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kvtecaccord »</TD></TR><TR><TD CLASS="quote">Its missin pretty bad, almost sounds like a WRX.</TD></TR></TABLE>
there you have it. you smoked your ring lands I will put money on it.
every time I toasted a stock piston my car sounded just like a WRX. get a compression test done, but I'm willing to bet your motor is el gonzo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">
every time I toasted a stock piston my car sounded just like a WRX. get a compression test done, but I'm willing to bet your motor is el gonzo.</TD></TR></TABLE>
From his description I would have to agree with you on this.
yeah, I just talked to a honda head and head said I may have lost the cylinder. I sure hope not. I am going to do the compression test to see where it reads. That will help eliminate some things and let me know where to go from there. If thats the case, I hace a H22 swap lined up for $800 for engine, tranny and ecu. So I guess bad things happen for good reasons, atleast for Hondas that is.
Well, the bad news is here. I pulled my plugs today after replacing the cap and it showed no improvements. Well, when the plug was pulled for #2, there it was, oil on the plug. Looks like I have some fun coming up.
WRX motor in a Accord would be nice though. LOL Anyhow, just means its time to upgrade. Anyone have some pistons and rods for sale??? I am trying to get a H22 swap from a dude for $800, includes tranny, ecu and motor. Can't go wrong with that. Not sure if I still want to do a compression test. I am sure the rings are gone and afraid that the piston may have got that little piece of spark plug and scored the cylinder wall. Will find out soon enough. I will keep you all posted. Thanks for all the replies guys.
