b18c1 head off..ideas?
Old Aug 12, 2005 | 11:49 AM
1990hondaHF's Avatar
Default b18c1 head off..ideas?
I bought a 90 hatch with a b18c1 swap but unfortunatly it has bad valves on one of the cylinders.....since I'm going to take off the head, should I mill the head a few? What is the stock compression ratio of the 94-95 b18c1? Also, is the b18c or the b18c1 JDM?
Old Aug 12, 2005 | 12:06 PM
Mach69's Avatar
Default Re: b18c1 head off..ideas? (1990hondaHF)
Well, if you mill the head, it will raise your compression, but not by a lot. And yes, I would get it milled. Mill just enough to make it straight. I had my z6 head milled to make it straight, and I think 2.5 thousandths were taken off.
Stock Compression... 10:1, i think.
The b18c1 is from the USDM Acura Integra GSR. The b18c5 is from the USDM Acura Integra Type R.
SweatDaTeck
May 21, 2013 10:12 AM
pinoyk20
Jul 9, 2006 01:31 PM
DSR!
Oct 22, 2004 04:53 AM
g's integ
Jun 11, 2002 01:03 AM
strils
Dec 27, 2001 08:02 PM
