about jdm sidemarker
Old Aug 12, 2005 | 08:49 AM
g2xsi's Avatar
Default about jdm sidemarker
just a question for you guys that have jdm sidemarkers..
how do you wire them? i mean does it goes with the turn signal, or it goes with the park light..? meaning does it blinks or just stays on?
Modified by g2XSi at 6:01 PM 8/12/2005
Old Aug 12, 2005 | 08:59 AM
jay_c's Avatar
Default Re: about jdm sidemarker (g2XSi)
mine are both parking lights and turnsignal.
Old Aug 12, 2005 | 09:02 AM
g2xsi's Avatar
Default Re: about jdm sidemarker (jay_c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_c &raquo;</TD></TR><TR><TD CLASS="quote">mine are both parking lights and turnsignal.</TD></TR></TABLE>
is it supposed to be like that in japan..?
Old Aug 12, 2005 | 09:12 AM
LSvtec03's Avatar
in "jdm-land," they should stay off until you signal.
Old Aug 12, 2005 | 09:54 AM
g2xsi's Avatar
Default Re: about jdm sidemarker (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">in "jdm-land," they should stay off until you signal.</TD></TR></TABLE>
thanks guys..
Old Jan 1, 2006 | 06:30 PM
wlee112's Avatar
I was wondering how i could make my DA6 sidemarkers stay on and blink. could you help me. thx
Old Jan 1, 2006 | 07:44 PM
Finger Lickin' good's Avatar
Default Re: about jdm sidemarker (wlee112)
you were wondering? WHAT? just ******* wire it up with your other turn signal???
Old Jan 1, 2006 | 08:20 PM
wlee112's Avatar
Default Re: about jdm sidemarker (Finger Lickin' good)
i want the side markers to have the function of a corner light (parking lights) and the blinkers (turn signals)
Old Jan 1, 2006 | 09:48 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Old Jan 2, 2006 | 03:43 AM
MenaceL.A.671's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">in "jdm-land," they should stay off until you signal.</TD></TR></TABLE> TRUE!!!
Old Jan 3, 2006 | 01:13 AM
wlee112's Avatar
Default Re: about jdm sidemarker (m2slsvtec)
is it better to stick to jdm? everyone likes that more? wouldnt people want the side marker to stay on thought? NO ONE has constant side markers that also blink... i like that...
Old Jan 3, 2006 | 01:17 AM
teknoracing's Avatar
True that.
IF you want them to stay on switch the negative on sidemarker to turnsignal wire of bumper light
Old Jan 3, 2006 | 08:56 PM
wlee112's Avatar
Default Re: about jdm sidemarker (teknoracing)
where does the positive connect to? what will this result in?
Old Jan 3, 2006 | 09:34 PM
SpoonTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wlee112 &raquo;</TD></TR><TR><TD CLASS="quote">where does the positive connect to? what will this result in?</TD></TR></TABLE>
if you want to have your sidemarkers blink and stay on constantly.....just splice into the corner light that blinks and stays on constant.....
pretty easy stuff!
Old Jan 3, 2006 | 10:13 PM
gsr dood's Avatar
Default Re: about jdm sidemarker (SpoonTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonTeg &raquo;</TD></TR><TR><TD CLASS="quote">if you want to have your sidemarkers blink and stay on constantly.....just splice into the corner light that blinks and stays on constant.....
pretty easy stuff!</TD></TR></TABLE>
its not that easy my friend. they have dual filament bulbs with 3 wires in the corner light. the side marker is a single filament. u have to wire a pos to the green of the runing light and a pos off the corner blinker light.....im in the process of actually wiring it ill let u all know hpow its supossed to be wired
Old Jan 3, 2006 | 11:52 PM
Naruto's Avatar
Default Re: about jdm sidemarker (gsr dood)
I'm not too familiar with DA wiring harnesses for these things, but on my DC4 I had wired the JDM OEM sidemarkers to stay constant AND blink when the turn signal was activated. Talk about a bad mistake.....the ECU went out shortly after that and I couldn't start my car anymore. I had everything checked out...wiring underneath the dash.....etc etc. It was the sidemarkers and how they were wired ( which will be described below ). Apparently, it caused too much of a load on the stock relay or something ( I forget ) and somehow my ECU ended up being adversely affected by it ( how...I dunno because when I replaced the ECU and disconnected the sidemarkers...car started up fine ) Now...it will work, BUT, if the DA wiring harness for the turn signals are generally the same as the DCs then I would not recommend having the sidemarker do both as you only get two wires ( or two connections for the wires ). One...has to be a ground. The other....there you have a choice of it either staying constantly on, or act as a blinker along with your turn signals. Can't have both. At least...on the DCs anyway. If you can do it on the DA's....sure, just tap or splice one wire into the constant, the other into the "accessory" or the wire that allows the bulb to flash.
You'd be better off getting a sidemarker with harness that includes 3 wires ( not sure if that's even available and I've never seen one with 3 wires ) but that definitely would not be JDM ( correct me if aftermarket in JDM land counts ...again...if they are even available...which I highly doubt. ). Its up to you. But I would definitely research your wiring harness first to see if that is "allowable" on your ride without anything causing a potential short or....what happened to me
Old Jan 4, 2006 | 12:09 AM
DRAMA's Avatar
Default Re: about jdm sidemarker (g2xsi)
I hate when people wire up their sidemarkers to turn on when their parking lights are on. that is the gheyest thing ever. wire them up so they only come on when the blinker is on.
Old Jan 4, 2006 | 12:29 AM
H.'s Avatar
H.
Default Re: about jdm sidemarker (StReEt TuNeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StReEt TuNeR &raquo;</TD></TR><TR><TD CLASS="quote">I hate when people wire up their sidemarkers to turn on when their parking lights are on. that is the gheyest thing ever. wire them up so they only come on when the blinker is on.</TD></TR></TABLE>
I think it looks sexyyyy.........
Old Jan 7, 2006 | 11:45 PM
wlee112's Avatar
Default Re: about jdm sidemarker (SoCalGsR1)
i agree they look god darn sexy
Old Jan 8, 2006 | 12:39 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2xsi &raquo;</TD></TR><TR><TD CLASS="quote">just a question for you guys that have jdm sidemarkers..
Modified by g2XSi at 6:01 PM 8/12/2005</TD></TR></TABLE>
A sidemarker, is a turn signal on the fender. Wire it up to your existing turn signals.
Old Jan 8, 2006 | 01:10 PM
Nexx's Avatar
Cause StReEt TuNeR got m4d JDM sk1llz!!!11!11!1!1111 JDM 4 evar!!!!
Manolo
Honda Civic (2006 - 2015)
14
Aug 25, 2008 06:33 PM
shifts
12
Oct 16, 2006 10:36 AM
igo4bmx
36
Jan 17, 2005 10:07 PM
SWEETDUDE
Dec 19, 2004 05:56 PM
Finger Lickin' good
Oct 26, 2004 02:36 PM
