Heat Sheilds/Dust shields
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">Remove them.</TD></TR></TABLE>
Seems the logical approach.
ding ding ding..
ram air effect with the shields.. funny stuff..
ding ding ding..
Wuts would be so funny about doing that. I have factory fog lights so brake ducts are out of the question. Do you have to use heat insulation tape on the lower ball joint when you take the shields off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor »</TD></TR><TR><TD CLASS="quote">Wuts would be so funny about doing that. I have factory fog lights so brake ducts are out of the question. Do you have to use heat insulation tape on the lower ball joint when you take the shields off?</TD></TR></TABLE>
Think about it for a second. Ram air ... how? How is air going to be rammed in there when you have a wheel with tire blocking airflow?
Lower, tie rod and anything else that you come across that might fail because of excessive heat. Oh, ABS sensor too.
Yea I was thinkin about the airflow as well. So wut should I do then, if you say the excessive heat might ruin the ABS sensor and the lower tie rod link how is everyone running without them and not having problems?
Instead of taking them off, I'm just going to drill an intake size hole and run ducting. I have the ducting mise well use it. I'll just take the fog lights out when I do trackdays.
allricedout
Suspension & Brakes
12
Aug 7, 2008 05:55 AM
