Pics of Neuspeed race/koni yellow setup...
i used to have that set-up, it was too low for me...now i have h&r sports w/ koni yellows...
I like the stance. It may be a little low for some, but if you're not driving your car 100+ miles a day. That setup should be just fine. double
for the Si rims.
for the Si rims.
How much of drop is that?
with high *** rates...like 500F 400R
not sure.
but im thinking its one rough ride, and i have sportlines.
and i think their pretty rough.
the drop is like 2.25 in front, 2.00 in back, but I put the koni's on the high perch in the rear so the back is a little higher. Ride is nice, a little stuff, but not "rough" or bouncy at all. And WOW does it hold the turns tight! I have a bit of an issue with my front camber, I forget how much its in, i think 2 degrees or something, but its not too bad, and the back camber is perfect.
[Modified by 97blackteg, 12:57 PM 2/22/2002]
Cool,because i have sportlines and I want it a little more slammed like 2 or 2.25.But without killing the smooth ride.My opionion thats sittin perfect.
[Modified by maggsgsr, 6:07 PM 2/22/2002]
i just went from race to sportlines only b/c i didnt want my car so low. RIde was fine though....oh yeah, the races are for sale adn are in really good condition
why do those corner lights look not stock?
(too yellow)
(too yellow)
you really do need a camber kit with the race springs, your tires will start wearing right away!!!! you mihgt not notice it until much later but once its off it is going to wear the tires....spend the money and get a camber kit and alignment soon
whats up looks great i have the comptech springs with the koni yellows on the low perch too, soon to post pics i got the ingalls camber kit my camber was off my about 3 degrees in the front and i put washers in the back, get the camber kit man its low but its not that slammed 2.25 is low but not that low i don't hit anything just be careful for curbs when you park (crunch) ouch, but looks badass
how much more can you lower you car with koni yellows? is it an actaully settin which lowers the car?
