Need a rear end for a 92-95 civic 2door coupe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattandrews »</TD></TR><TR><TD CLASS="quote">Looking for any type of rear end except stock. If you have one message me.
If by rear end you mean rear differential and axles, you're SOL unless you plan on fabbing your own. If so, I'd go with a Chevrolet S10 *** end because they're cheap and relatively strong. They also come - most of them, anyhow - with 3.73's which will motivate whatever engine you have to push your Civic rather quickly.
The B20 CRV rear suspension and diff can be made to work, but it's neither strong nor simple to work with.
</TD></TR></TABLE>If by rear end you mean rear differential and axles, you're SOL unless you plan on fabbing your own. If so, I'd go with a Chevrolet S10 *** end because they're cheap and relatively strong. They also come - most of them, anyhow - with 3.73's which will motivate whatever engine you have to push your Civic rather quickly.
