92 Legend Brake Issue - Help!
The brake fluid is coming out of the ABS Modulator resevoir when you apply the brakes without the engine running. I took the cap off and you can see it rising when the brakes are applied. The ABS system is working fine. There is pressure and it engages. The ABS light is not on. Do you think that the modulator is bad. I bought a used accumulator.
Thanks!
Thanks!
