Which nipple is IN/OUT on the TB for coolant lines? D16Y8
Old Aug 12, 2005 | 02:27 AM
Accurate GS-R's Avatar
Default Which nipple is IN/OUT on the TB for coolant lines? D16Y8
I'm wondering if anyone knows if there even is an In or an Out on the throttle body for the two coolant lines that run to it? They're are two nipples next to each other on the TB (both for coolant lines) and I'm not sure if there's a one-way valve? I assume any line can enter from either nipple and exit through the other?
Thanks
Old Aug 12, 2005 | 06:31 AM
ntrider's Avatar
Default Re: Which nipple is IN/OUT on the TB for coolant lines? D16Y8 (Accurate GS-R)
Here is a pic of a civic IM with the coolant lines for the TB. I colored them red and circled the nipples, not sure if this is what you need.
hopefully pic shows up, first time posting
Old Aug 12, 2005 | 10:48 AM
gftgrill's Avatar
yeah, should be
IN - right
OUT - left
GooseS2000
Mar 21, 2013 08:25 AM
STPREZ
Aug 12, 2005 08:17 PM
85mm LS VTEC
Apr 11, 2005 11:06 AM
Sinner
May 29, 2003 10:42 AM
Floyd91
Jul 25, 2001 06:32 PM
