Brake Piston Help ASAP!
Old Aug 11, 2005 | 10:58 PM
Britton4eb's Avatar
Default Brake Piston Help ASAP!
Hey what's up pep's. I need some help with my brake Piston. I'm tring to figure out how to get the piston back into the caliper. Now :NOTE: I am not a skilled at working on cars. My feild is in Computer Hardware. But I do know a little bit, also to add that I know that you must use a ''C Clamp'' to get the brake piston is the caliper. Which I tried for 2hours trying to get the pistion in but it won't bude.
Now I'm trying to figure out, why the piston won't bude (the brake was down also). Hmm, is there anything that I should do? I even bleed the brakes, well lets say I had a hard time to get the bolt back on so there is no brake fuild but in the morn I will take care of that. Please, let me know if you have any Ideas ASAP.
Again, my Brake Problem is: The Piston Won't Slide Back Into The Caliper.
Thank You
Old Aug 11, 2005 | 11:04 PM
TODA GS_R's Avatar
im guessing your talking bout the back? if it is...you gotta twist it clockwise. i never had a prob like that to the front though
Old Aug 11, 2005 | 11:08 PM
gsr dood's Avatar
Default Re: Brake Piston Help ASAP! (Britton4eb)
ok listen u need a c clamp for the front calipers and a chisel to screw in the rears clockwise it should slide easy. if u use a c clamp on the rear calipers there fucked if they wont budge there wat they called "frozen calipers" in which case u need to replace the caliper because it no lonfer works its commmon ive had it happen on both my rears easy fix. they sell em at uto barn pep boys auto zone napa anywhere for like 30 a piece? maybe
Old Aug 12, 2005 | 11:32 PM
Britton4eb's Avatar
Thx, My Buddy (Mech) told me too. I got everything straight except that was the 1st time I change brake my brakes. I would normaly take it to the shop. Also note, I pulled out the brake line so I need to bleed the whole system this week. Thank you again.
Also anyone know where I can get some parts online for a 91 Integra? I'm looking for a lot of after martket parts.
Please let me know.
yingvang27
Apr 14, 2014 02:18 AM
leviq
Jul 7, 2007 08:28 AM
HGZ
Sep 6, 2004 11:14 AM
blackEF
Jun 7, 2002 08:50 PM
KhRoNiX
Dec 19, 2001 10:18 AM
