valve clearance specs for skunk 2 stage 2 ?
Old Aug 11, 2005 | 10:12 PM
92gsr1's Avatar
Default valve clearance specs for skunk 2 stage 2 ?
i need to know what both intake & exhaust valve clearance specs?
can any body tell me or point me where i can find it
Old Aug 12, 2005 | 09:04 AM
unusual71's Avatar
heres a good place for specs
http://www.allmotorhonda.com/t...s.htm
but as far as clearance, i think we'd need to know in what head and on what block crank pistons et cetera.. ya know
Old Aug 12, 2005 | 11:18 AM
Rocket's Avatar
Default Re: (unusual71)
0.007/0.009" in/ex (cold) will work.
Feel guage should have slight drag and next higher thickness will not go thru.
Old Aug 13, 2005 | 04:15 PM
92gsr1's Avatar
thanks rocket
Old Aug 17, 2005 | 03:33 PM
JFG Kevin's Avatar
Default Re: (Rocket)
Is there anything to comfirm that? cause i try to do a valve adjustment on my stage 2 and with stock clearance..it wasn't working..
Old Aug 17, 2005 | 08:11 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">0.007/0.009" in/ex (cold) will work.
Feel guage should have slight drag and next higher thickness will not go thru.</TD></TR></TABLE>
The BEST way to make sure you are 100% dead on is to use "will go won't go" feeler gauges. Thats what a lot of the pros use and they are dead on.
Old Aug 24, 2005 | 03:24 PM
B17AGSR's Avatar
Default Re: valve clearance specs for skunk 2 stage 2 ? (92gsr1)
I thought I already told you this, checking behind me?
Old Aug 24, 2005 | 04:28 PM
GUILOTINE's Avatar
Kill Gil
The adjustment recomended by skunk on the spec sheet that came with my Stage 2's is .007in/.008ex with slight drag
To double check what I do is make sure that a .008 in the intake and a .009 exhaust dont fit
screen_name
Jul 31, 2006 10:24 AM
JFG Kevin
May 19, 2006 07:19 AM
sbcs15
Sep 12, 2005 09:46 PM
mgast
Feb 23, 2003 06:59 AM
wade95gsr
Jan 23, 2003 12:59 PM
