engine removal questions
Old Aug 11, 2005 | 09:27 PM
AK77's Avatar
Default engine removal questions
Hi, I'm removing b18a from my integra LS. Most of the stuff is off except for 2 things:
1. Shift linkage - if I go about detaching this from underneath the center console, how hard is it to detach that pin/cable and is it like a pin or a screwed in connector?
2. There is a cable underneath the intake, going directly into the engine, pretty thick cable, can;t see it but it's not coming off either. Should I just partially lift the engine and then try to take it out or do what?
Any help would be greatly appreciated, thank you very much!!!
Old Aug 11, 2005 | 10:32 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: engine removal questions (AK77)
What year Integra? Sounds like that may be your clutch cable?
And yea, that bitch pin on the shift linkage SUCKS to get out. Be patient.
Old Aug 12, 2005 | 07:29 AM
AK77's Avatar
1991 Integra LS, Automatic, so can;t be the clutch cable. I know it's going to the shift box so has to be the shift linkage. So how hard is it to detach it from the shift box? I know there's a pin as well to detach.
dansaleen_04
Oct 6, 2010 02:36 PM
ChrisRicketts
Feb 1, 2005 02:41 PM
CRX_Control
19
Nov 11, 2004 12:31 PM
FLyPimp
Apr 9, 2003 01:24 PM
