d16z6 dizzy!
Old Aug 11, 2005 | 09:11 PM
KURUPTinc's Avatar
Default d16z6 dizzy!
just wondering if i can use the d16z6 off a 93 civic by just changing the plugs?
Old Aug 11, 2005 | 11:05 PM
gnar kill's Avatar
Default Re: d16z6 dizzy! (KURUPTinc)
if your motor is the stock si motor the bolts won't line up....
Old Aug 14, 2005 | 10:34 AM
KURUPTinc's Avatar
Default Re: d16z6 dizzy! (gnar kill)
well im putting the whole d16z6 into my 91 hatch but im using the old harness and was wondering if i could just change connectors?
Old Aug 14, 2005 | 10:36 AM
gnar kill's Avatar
http://www.rywire.com sells an adapter for 25 bucks that will let you use your stock harness and it will all plug right in...or you can rewire yours.....are you converting to obd 1 and running a p28 ecu? because if not I HIGHLY recomend it
casey
ILcrxsi1's Avatar
I tell doctors what to do
if you're converting to obd1 you need to use the z6 dizzy and if you're not, than no you can't use that dizzy.
Old Aug 14, 2005 | 10:39 AM
KURUPTinc's Avatar
Default Re: (illcrxsi1)
so i cant use the plugs from the z6 harness and switch with the old harness? i know theres going to be missing some wires. like two i think
Old Aug 14, 2005 | 10:43 AM
ILcrxsi1's Avatar
Default Re: (KURUPTinc)
no you can switch plug connectors, but only if you're converting to obd1. an obd1 dizzy will only work with an obd1 ecu.
alexzhere
Jun 4, 2013 01:35 PM
crxblues
Mar 30, 2009 07:41 AM
daredeezy619
Nov 21, 2008 04:38 PM
PiXeL
Sep 19, 2006 05:16 PM
EARLdaSQUIRREL
May 20, 2003 11:15 AM
