gains from new cams and cam gears
Old Feb 21, 2002 | 09:01 PM
bocian's Avatar
Default gains from new cams and cam gears
ok now i know that cam gears will need tuning but will there be any gains if i just replace the cams and cam gears?
tia
Old Feb 21, 2002 | 09:16 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: gains from new cams and cam gears (bocian)
It depends on what cams you get. If you simply replace the cam gears and have them set at 0 degrees plus or minus, then it'll perform exactly like stock.
Cam power will depend on what type of cams you get. You can get mild ones, which require no springs/retainers, or really crazy lumpy ones which need springs/retainers.
A mild set of cams with tuned gears will give you around 5-10hp at the wheels. A real wild cam with all the proper headwork and tuned gears can net you anywhere from 10 to almost 30+hp at the wheels.
Guys, help me out there. Do those numbers sound right?
da_all_day
May 29, 2011 09:45 AM
hondacrx2
May 31, 2007 06:51 PM
MDintegra95
May 5, 2005 08:28 AM
acuratuner00
Oct 14, 2004 06:09 PM
dvp95
Sep 5, 2003 01:12 PM
