2000 Si Misfiring HELP!!!
Ok as stated above my check engine light comes on and some times it will start to blink (for example getting on the freeway) the code it gives me says i have a miss fire or to check my entire ignition system. So i changed the
Wires, plugs, cap, rotor, fuel filter, timing belt, waterpump, re adjusted the valve lash and some other stuff the usual @ 115k miles.
the weird thing is the car is running fine it still drives strong
if any ting i belive #1 piston is the one mis-fireing due to the abnormal amount of carbon buildup on the plug.
or 2 could it be teh supah JDMyo ricer fart cannon with a 2.5 inch piping W/O a resonator because it shure does backfire when i let off the gas.
any help would be great
-JMi-
if any ting i belive #1 piston is the one mis-fireing due to the abnormal amount of carbon buildup on the plug. or 2 could it be teh supah JDMyo ricer fart cannon with a 2.5 inch piping W/O a resonator because it shure does backfire when i let off the gas.
-JMi-
I need to go back to Vato Zone for the specific code all they told me was it was a misfire then tried to sell me some plugs and wires
code P1336 which is a crankshaft/ camshaft sensor performance....
what the hell does that mean it also gave the codes for a misfire in banks 1,2,3,4, and the code for a random misfire. the thing is the car still seems to be running right this sucks
Sometimes when doing a timing belt service on Civics (maybe others, too), if you don't tuck in the crankshaft sensor, one of the belts will chew through the shielding causing problems. I would also imagine that a faulty crankshaft sensor would cause misfires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm »</TD></TR><TR><TD CLASS="quote">Sometimes when doing a timing belt service on Civics (maybe others, too), if you don't tuck in the crankshaft sensor, one of the belts will chew through the shielding causing problems.</TD></TR></TABLE>
that was my problem right there now i get code 1337 -no RPM signal....but my tach still works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DeepCivic »</TD></TR><TR><TD CLASS="quote">Your tach is getting signal from the distributor. I got that code before and a chewed up crank sensor was the cause.</TD></TR></TABLE>
i re wired that it was chewed up maybe the sensor itself is bad?
ItsMikeBABY
10
Apr 3, 2010 09:48 PM
jeremy8886
Dec 7, 2005 06:54 PM
bigedx
Feb 6, 2004 01:50 PM
