WEDDING CRASHERS -garage sale-
<FONT SIZE="4"><FONT COLOR="blue">ALL PARTS LOCATED IN <U>LOS ANGELES/SAN GABRIEL VALLEY</U></FONT></FONT>
<FONT SIZE="5"><FONT COLOR="green">!MORE PARTS AND PICTURES ADDED TO THE LIST!</FONT></FONT>
1. BRAND NEW 2005 odessey center optional seat: $225
2. JDM EK COLUMN LIGHT:
http://www.hondamarketplace.co...39848
1998-01 integra ONE ls mesh wheel with tire: !SOLD!
jdm EK9 26mm front sway bar: !SOLD!
jdm EG6 rear sway bar 15mm: !SOLD!
jdm EG6/EG2 BRONZE alloy wheels with tires: !SOLD!
1992-95 civic uspec optional 14inch alloy wheels with tires: !SOLD!
14 inch stock/steelies/blacks wheels with tires(set of 4): !SOLD!
jdm <U>gsr/sir-g/si-vtec/FAT FIVES</U> with H center caps and tires: !SOLD!
AEM front and rear brake pads(dc) <U>used under 500 miles</U>: !SOLD!
<FONT SIZE="5"><FONT COLOR="red">SHIPPING IS ADDITIONAL</FONT></FONT>
1. uspec 1996(obd2a) gsr ecu: $100
2. 1994-01 gsr front lower shock forks: $25
3. 1994-01 gsr front upper a-arms: $25
4. 1992-95 civic rear lower control arms: $30
5. misc. eg/dc mounts: $10each
6. 1992-95 civic coupe/hatchback stock front corner lens: $10
7. 1994-01 integra <U>front right</U> brake caliper with bracket: $40
8. 1992-95 civic si(black) e-brake cover: $15
9. 1994-01 gsr throttle cable: $10
10. 1994-01 gsr rear disc rotors: $20
11. jdm itr flywheel: $100
12. obd1>obd2a evassive conversion harness: $50
13. 2001 gsr flywheel(under 50,xxx miles): $30
14. 2001 gsr clutch(under 50,xxx miles): $30
15. 2001 gsr open differential(under 50,xxx miles): $100
16. 2001 gsr final drive(under 50,xxx miles): $150
17. 2001 gsr intake manifold(under 50,xxx miles): $40
18. <FONT COLOR="red">EIBACH</FONT> prokit lowering springs for (eg/dc) chassis: $100
uspec 1995(obd1) gsr ecu: !SOLD!
<FONT COLOR="red">SUSPENSION TECHNIQUES</FONT> front sway bar(eg/dc) <U>HARDWARE ONLY</U>: !SOLD!
jdm itr P73 ecu: !SOLD!
1994-01 p72 gsr oilpan: !SOLD!
2001 gsr throttle body(under 50,xxx miles): !SOLD!
<FONT COLOR="silver">AEM</FONT> cold air intake for 1994-01 gsr: !SOLD!
<FONT COLOR="blue">B&M</FONT> short shifter(eg/dc): !SOLD!
1994-01 gsr front strut bar: !SOLD!
<FONT COLOR="red">NEW</FONT> energy suspension motor mount inserts(94-01integra & 99-00si) <FONT COLOR="red">part number 16.1106</FONT>: !SOLD!
1990-93 DA6 integra coupe rear wing(phantom gray) with 3rd brake light: !SOLD!
<FONT COLOR="green"><FONT SIZE="6"><U>HURRY SCROLL DOWN FOR PICTURES, THEN BUMP THE POST AFTER VIEWING</U></FONT></FONT>
Modified by eg6sir-s at 10:28 PM 3/5/2006
AEM front and rear brake pads(dc) <U>used under 500 miles</U>: !SOLD!<FONT SIZE="5"><FONT COLOR="red">SHIPPING IS ADDITIONAL</FONT></FONT>
1990-93 DA6 integra coupe rear wing(phantom gray) with 3rd brake light: !SOLD!<FONT COLOR="green"><FONT SIZE="6"><U>HURRY SCROLL DOWN FOR PICTURES, THEN BUMP THE POST AFTER VIEWING</U></FONT></FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]</TD></TR></TABLE>
wheres the beef?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
wheres the beef?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird »</TD></TR><TR><TD CLASS="quote">
wheres the beef?</TD></TR></TABLE>
patience is a virtue. i want to make sure i get everything covered on the post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1times »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blivic »</TD></TR><TR><TD CLASS="quote">might take that gsr strut bar off your hands. i'll give you a call if i do.
bump
bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyzalvarez »</TD></TR><TR><TD CLASS="quote">bumpo </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">up</TD></TR></TABLE>
if only i had the cash, bump it up for a good seller and a friend!!
</TD></TR></TABLE>if only i had the cash, bump it up for a good seller and a friend!!
