Help! Turn signal aint working!
Old Aug 11, 2005 | 07:11 PM
jedubz's Avatar
Default Help! Turn signal aint working!
Hey guys, my turn signal isn't working. When I flip the switch, or turn on the hazards nothing happens. I know that I am missing the two bulbs in the front for the bumper lights, but the corners (front and rear) all don't work when I try to turn or put the hazards on. I checked the fuse and it looks solid so I'm confused... Anyone have any suggestions?
Old Aug 12, 2005 | 02:11 PM
jedubz's Avatar
Default Re: Help! Turn signal aint working! (jedubz)
Not to mention, when I switch on the turn indicator / hazards, the I hear no clicking or see no lights in the gauge cluster indicating that the turn signal is on. PLEASE SOMEONE HELP!!!!!
Old Aug 15, 2005 | 02:15 AM
jedubz's Avatar
High beams also don't work. Come on! ANYONE WITH ANY EXPERTISE JUST GIVE ME SOME HINTS!
Old Aug 15, 2005 | 07:22 AM
d15civ's Avatar
Default Re: (jedubz)
ive never had this problem, but did you check your fuses
Old Aug 15, 2005 | 11:41 PM
jedubz's Avatar
Default Re: (d15civ)
Yes, I'm so lost.
Old Aug 16, 2005 | 04:13 AM
crx34's Avatar
Check your Relay & grounds
Old Aug 18, 2005 | 12:56 PM
jedubz's Avatar
Default Re: (crx34)
I tried taking the relay (where the actual turn signal lever is attached) from my other car, which worked and it still didn;t work when I plugged in the two wire-clips. Where are the grounds located?
92eg_b16
Oct 19, 2008 12:52 AM
92civicGA
Mar 2, 2007 10:22 AM
moleodonuts
Sep 13, 2005 02:00 PM
BrownGSR
Mar 16, 2004 09:19 AM
EGTeK
Mar 26, 2003 10:52 AM
