Stupid question
Old Aug 11, 2005 | 07:07 PM
vbspec's Avatar
Default Stupid question
To put a 99 LS motor into a 93 RS, going OBD2 99 to OBD1 93
I just need to change the distributer and alternator from thr 93 on to the 99 motor?? Right???
Old Aug 11, 2005 | 07:10 PM
adaml2nv's Avatar
Default Re: Stupid question (vbspec)
and injectors
Old Aug 11, 2005 | 07:11 PM
JUN-DA6's Avatar
If you don't want to repin the distributor plug...yes it is easier just use obd 1 distributor. About the alternator they should fit the same unless they change the alternator plug too then you can just use your 93 alternator.
good luck!
Old Aug 11, 2005 | 07:13 PM
vbspec's Avatar
Default Re: Stupid question (JUN-DA6)
Awsome!!!
THANX
Old Aug 11, 2005 | 10:14 PM
LSTEG96's Avatar
not to mention some sensors on the back of the block are different in the obd1 car... the sensor for the obd2 coolant temp is in the thermo housing instead of in the block on an obd1 car... i sucks.
Old Aug 12, 2005 | 09:04 PM
JUN-DA6's Avatar
Default Re: Stupid question (LSTEG96)
My 92 GSR coolent temp. sensor is also on the thermostat housing, and it is OBD 1 car.
760dc4
Jun 19, 2009 09:20 AM
hammergunner
Mar 20, 2009 12:51 AM
GsrVtec
Sep 12, 2006 08:20 PM
o5mar1
Aug 8, 2006 06:22 PM
ANGELL
May 24, 2003 03:18 PM
