Suspension & Brakes Theory, alignment, spring rates....
installing ST rear sway bar on 89 CRX Si
Old Aug 11, 2005 | 04:12 PM
JustinHoMi's Avatar
Default help installing ST rear sway bar on 89 CRX Si
Just got the Suspension Techniques rear sway bar for the 89 CRX Si... I'm a bit confused about installation.
The instructions say to knock off the lower shock mounting nut with a chisel, but on the forums someone nonchalantly said that is only for non-Si's. Is this correct?
What is the best way to install this sway bar?
Thanks!
Justin
Old Aug 11, 2005 | 05:00 PM
loodood's Avatar
Default Re: help installing ST rear sway bar on 89 CRX Si (JustinHoMi)
i'm pretty sure what he meant was that the si's came with a rear-sway, and they mount in a totally different fashion than the st's. i think if someone with an si was to use the st bar they would have to knock off that nut also. i may be wrong tho.
Old Aug 11, 2005 | 06:49 PM
CRX Lee's Avatar
Default Re: help installing ST rear sway bar on 89 CRX Si (loodood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loodood &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure what he meant was that the si's came with a rear-sway, and they mount in a totally different fashion than the st's. i think if someone with an si was to use the st bar they would have to knock off that nut also. </TD></TR></TABLE>
You are correct. Even though an Si has it's own sway bar holes in the lower control arm, you cannot use them with the ST rear bar so Si people will also have to remove the lower shock mounting nut and bolt the sway bar mounto that point.
I have an Si and an ST sway bar that I have never yet installed because I wanted to find a way to mount it to the lower control arm and not remove the shock nut (too much of a purist). I have not figured out how to do it yet and doubt that it will be possible.
Old Aug 11, 2005 | 06:56 PM
JustinHoMi's Avatar
Default Re: help installing ST rear sway bar on 89 CRX Si (CRX Lee)
I'm a bit concerned about taking the lower shock bolt out... won't the shock decompress?
Old Aug 11, 2005 | 07:40 PM
Johnny Mac's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustinHoMi &raquo;</TD></TR><TR><TD CLASS="quote">I'm a bit concerned about taking the lower shock bolt out... won't the shock decompress?</TD></TR></TABLE>
Jack the car up and put it on jackstands. Remove wheel and tire. The suspension is in full droop. Remove lower shock bolt and you're ready for the next operation.
Old Aug 11, 2005 | 08:01 PM
JustinHoMi's Avatar
Hahah, I don't know what I was thinking....
Vagitarian
15
Oct 7, 2013 11:08 AM
ryanmh22
10
Apr 8, 2013 03:03 PM
ThefirstPACT
22
Feb 8, 2005 11:42 AM
crx98
Jun 14, 2003 04:54 PM
