IS MY TIMING OFF ???
looks to be at full advance from the pictures... having problems with pinging?
as stated above, use a timing light... setting ignition timing is something that you shouldn't be guessing at.
http://www.c-speedracing.com/h...g.php
You can't tell if your timing is off by looking at old ware marks on your distributor, you have to check it with a timing light. Also, you might want to put a breather filter on your oil vapor line or reconnect it to your intake system. They will keep dirt, dust and quite a bit of moisture out of your engine's internals.
yah it looks to be fully advanced.... there is wear marks on the dizzy where it should go... most of the time when the timing is dead on... the 3 bolts are in the center of the adjuster... equal length of metal on both sides of the bolts... thats usually tdc.
koa
May 24, 2018 12:05 AM
Magick211
Dec 11, 2001 04:29 PM
