WHAT A BAD DAY!!!!
Old Aug 11, 2005 | 01:05 PM
gsr dood's Avatar
Default WHAT A BAD DAY!!!!
well last week by ball joint startin clunkin everytime i would take off or brake really hard. so today i dcided to take a peek and saw i had a really loose ball jont nut and the cotter pin was missing. so i figured it would make it to autozone 2 miles away. i pay my god damn 29.95$ for the ball joint.
so i pull out of autozone back onto sunrise highway throw it into second gear and BANG! clunk clunk clunk clunk......POP!!!!!(passenger airbag )...clunk clunk clunk......so i pull over my friend is laughing the air bag didnt even hit him cuz he was sittin back in his seat and had a seat belt... im flippin out.
so i call my tow man he comes and takes it to the shop. we raised up the car. the nut of the ball joint fell out the control arm shot in between the spokes of my rim and broke 2 spokes out of my ls webs i need a new LCA and my axle ripped nd was spittin axle grease everywhere. and im gunna just get a jmd tray for that passenger air bag **** sux. PLEASE DONT BE A RETARD IF UR BALL JOINT IS ACTING UP GET IT FIXED AS SOOON AS IT MAKES NOISE. ahhhhh now tooo fix this dammmn thing i should have pics tommroow.
Old Aug 11, 2005 | 01:10 PM
Guru Designs's Avatar
* B A N N E D *
Ouch. Ive had customers with tie rod ends comming loose but never a ball joint. and if your interior is tan i have an extra airbag for sale let me know
Old Aug 11, 2005 | 04:22 PM
gsr dood's Avatar
Default Re: (tobe2be)
pm me
Old Aug 11, 2005 | 04:30 PM
RuskeR's Avatar
damn!
Old Aug 11, 2005 | 04:42 PM
hawjboi's Avatar
Default Re: WHAT A BAD DAY!!!! (gsr dood)
dayem that sucks...
txracer's Avatar
Default Re: (RuskeR)
how can you tell when i a ball joint is acting up?
Old Aug 11, 2005 | 05:09 PM
gsr dood's Avatar
Default Re: (txracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txracer &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell when i a ball joint is acting up?</TD></TR></TABLE>
very noticable. wen u switch gears the car makes a clunk type of noise u feel it more than u hear it it could be either a loose ball joint or a shot ball joint. wen the engine transfers the power to the axles the car raises then lowers slighty and if its loose i really cant explain it its a pretty noticle sound also make sure to check those cotter pins my nuts fell off because some shady shop put in my clutch and probably forgot to put the cotter pin in. ********. a good way to check is to take off ur wheel and lift the rotor assembly up. if theres any play (if it moves up and down) where the ball joint is make sure u replace it
Old Aug 11, 2005 | 05:35 PM
the_23rd_letter's Avatar
Default Re: (gsr dood)
ouch... if your doing this at home the p/s drive axle can be a bitch to get out. good luck!!!
Old Aug 11, 2005 | 05:53 PM
txracer's Avatar
thanks, always good to know this stuff
Old Aug 11, 2005 | 06:53 PM
JohnWayne's Avatar
Does Autozone stock the ball joints or do u have to get them ordered, also are they easy to replace?
I also have to get new cotter pins, do I have to go to the dealer?
Does Acura or Autozone carry replacement bolts for stripped bolts for the tranny and such or are they a soecial order?
Sorry for the thread jack!!
Old Aug 11, 2005 | 08:05 PM
gsr dood's Avatar
Default Re: (JohnWayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnWayne &raquo;</TD></TR><TR><TD CLASS="quote">Does Autozone stock the ball joints or do u have to get them ordered, also are they easy to replace?
Sorry for the thread jack!!</TD></TR></TABLE>
its quite alright. there not toooo easy to replace ive done a couple theres a couple tutorials on this site that go through step by step the hardest part it breaking it free just a couple hits with a hammer id say its fairly easy. COTTER PINS! dont drive ur car a day more without cottor pins you will regret it like i did. they sell cottor pins anywhere home depot hardware stores ace anywhere. yeah i went to pep boys not autozone sorrry and yes they carried them in stock. i went to napa first and they were gunna order them for me so i said **** it they should have em in stock. for ur tranny i would go to the hardware store and try and find the right bolt just bing the bolt with u and try and find the right size.
Old Aug 11, 2005 | 09:12 PM
gsr dood's Avatar
Default Re: (the_23rd_letter)
yeh it happed to my drivers side ha y is the ps side sooo hard wen i installed my clutch the ps side was giving me a hard time i ended up not even pulling out the axle i puled the axle from the tranny and just removed the whole front knukle with it. watt gives with the ps axle?
White_EG1
22
May 21, 2018 10:20 AM
BruceLee5000
15
Mar 7, 2017 04:34 AM
mark2583
Nov 30, 2007 07:46 PM
GruvyTune
Jul 22, 2002 10:01 AM
kilabeez
Sep 18, 2001 06:58 AM
