Question! dohc vtec rocker arms
Well heres the situation:
Exiting Freeway at idle, stop at red light..
Engine stalls(engine ran fine until then), can't get it to turn over
So get it towed home, Come to find out Toda Timing belt shreded.
And also I noticed I could not find the Crank key, that connects the crank gear to crank pulley, well set everything back up to TDC, picked up another crank key and replaced timing belt of course,but when I went to check valve clearances
I noticed Rocker arms on Exhaut side of cylinder #1 that I can move then up/down and they will not lock into place like all the other arms.. I am at work right now, and wont be able to do a through check/pull the head off till this weekend, Anyone give me some ideas of what it might be? thanks
I am a bit noobish when it comes to vtec valvetrain problems
its a b16b with Toda Spec C cams/portflow retainers/toda Valve springs, Stock Cam gears, thanks
civicboy420
Jun 5, 2014 09:13 PM
WalkerTexasRanger
Sep 7, 2012 09:06 AM
Gordon_B16
Feb 4, 2005 02:20 AM
