stalling problem
i have a 92 si stock motor, and i went to start it one day and it just kept turning over so i waited about 15 sec and turned it to acce and waited for the fuel pump to prime. and it started. i had no problems with it untill a couple weeks later it did the same thing except it was harder to get it started becuase it kept stalling and it would stall when i was driving it if i put the clutch in becuase the rpm would drop. im thinking its either a fuel pump or a main reley becuase i searched it before i posted this but im still not sure any sugg would be helpfull thanks
it would stall when you are driving? that is dangerous. dont drive that car until you fix the problem.
anyways, i get the same problem too but only when my car is parked in the sun too long and when i start it, the car dies. at first thought it was the battery cuz there is no power at all but it was the main fuel power relay. i change it and i never had that problem anymore.
i hope this helps
i hope this helps
mitchell_2kSiR
Dec 5, 2008 11:46 AM
civic efb16
Aug 11, 2005 03:47 PM
QUiKSR20
Jun 24, 2004 01:28 PM
