PROBLEM with a cable
Old Aug 11, 2005 | 11:50 AM
Svekke96's Avatar
Default PROBLEM with a cable
Hellow
I'm new here. I have a a problem with my 1992 Honda Civic Vti.
It has a loose cable underneath my dash.
The only thing that isn't working on my car is the horn.
Is this the reason, or for what is this cable, can you guys help me out please.
If it is a cable for the horn, where do I need to connect it too, because i don't see a please for it too fit in.
Old Aug 11, 2005 | 12:00 PM
Svekke96's Avatar
Default Re: PROBLEM with a cable (Svekke96)
Here's a better picture with the connection.
Old Aug 11, 2005 | 12:14 PM
AutoXer's Avatar
What color are the wires, and is there any way to see where the wires go?
Old Aug 11, 2005 | 01:12 PM
Svekke96's Avatar
Default Re: PROBLEM with a cable (AutoXer)
I can't see it really clear but this is what i see
It are 4 wires:
black with green wire
black with yellow wire
(black) with white wire
??? wire
I hope this helps you
Old Aug 12, 2005 | 09:16 AM
Svekke96's Avatar
I made a small drawing of the cable with the 4 connections.
Does anyone have an idea what it is for? Maybe the horn???
Old Aug 12, 2005 | 09:19 AM
sagron69's Avatar
I might be way off here, but i believe that's the wiring harness for the exterior fog lights, because it looks like the head is more brown than orange to me, but then again i dont know too much about the Vti. Good luck.
Old Aug 12, 2005 | 10:33 AM
moyo_rican's Avatar
Default Re: PROBLEM with a cable (sagron69)
dont worry bout it just wire tie it up out the way
Old Aug 13, 2005 | 01:22 AM
Svekke96's Avatar
If it is the harness for the fog lights, were do I need to connect it too?
Old Aug 13, 2005 | 10:11 AM
95DxSi-R2
Guest
Posts: n/a
i have no idea, if i worked at a honda dealer then i would know, maybe it's the data link connector. the horn only goes off of one wire, is the srs light on too?
Old Aug 14, 2005 | 12:09 PM
Svekke96's Avatar
Default Re: PROBLEM with a cable (95DxSi-R2)
thx for the info, i think its for fog lights, because my horn works again, it was just a bad contact between the metal pin in the steering wheel connection
The_Saint
Jan 28, 2010 06:41 PM
djnikko
Engine Management and Tuning
Dec 21, 2009 03:33 AM
Devo94ac
Mar 17, 2007 12:02 PM
JLefevers
Apr 8, 2006 06:21 PM
crxzc
Apr 15, 2002 07:33 PM
