what you guys think of the new setup
Old Aug 11, 2005 | 11:33 AM
Brycen's Avatar
Default what you guys think of the new setup
Setup:
94 Accord EX F22B1 Vtec motor
Turbonetics full turbo kit comes with blackbox
7-8psi (only cause still a stock motor with 170,000)
VAFC II
boost
air/fuel ratio
full Greddy Exhaust 3"
I won't be running very high boost yet due to the motor is still stock.I will be repalcing headgasket,valves,retainers,fully built head and bottom end by X-Mas.Just want to start the setup while ihave the money.Let me know what you guys think about the setup and what i should do in the next couple months to get higher boost.Trust me the kit will be installed by a known speed shop in Washingotn State.And yes i have all charges pipes for it. .. hahaha.
Old Aug 11, 2005 | 01:48 PM
spoolin-ls's Avatar
sounds nice! If you really plan on upping the boost, other than building the motor, I would suggest engine management. Make sure the car is tuned right, tuning makes all the difference! don't rely on the vafc or the management that comes with the kit if you plan of pushing some higher boost. and once everything is done lets see some numbers! good luck and have fun!
Old Aug 11, 2005 | 03:47 PM
Brycen's Avatar
Default Re: (spoolin-ls)
bump! heheh i will.I plan on having this boosted to about 7-10 or so no higher till i get money to yno it and tune it.Once i get the results ill post em up.
killakalipoph
May 20, 2009 09:44 AM
ProInline4
May 24, 2008 07:51 AM
athoughts
May 8, 2005 01:46 PM
cliff666
Apr 24, 2004 11:44 AM
