What is the maximum Final Drive ration ITR can go?
Old Feb 21, 2002 | 07:35 PM
nEoMuGen's Avatar
Default What is the maximum Final Drive ration ITR can go?
FD modification is pretty popular these days....everyone is getting a 4.7, 4.9 or even 5. So what is the limit of FD for our cars? What's the math behind it?
Old Feb 21, 2002 | 08:23 PM
BABY NSX's Avatar
Default Re: What is the maximum Final Drive ration ITR can go? (nEoMuGen)
5.0 is the shortest I've seen. I would imagine that a shorter gear would NOT be possible because of clearance issues with the tranny housing.
As well, the gear on the counter shaft would be so small that it might make the shaft to weak.
Regards,
Old Feb 22, 2002 | 06:26 AM
Ideal R's Avatar
New User
And a FD with ratio higher than 5 won't do any good (most likely).
You will get issues like traction, gears being too short and need to shift too frequent, terrible top speed etc. (unless you customize all the gear set ratio)
Old Feb 22, 2002 | 07:20 AM
AssPenny's Avatar
Default Re: What is the maximum Final Drive ration ITR can go? (ITR #01-1203)
Just throw a 6 speed in... yummmmmy
http://www.quaife.co.uk/product/gearbox.htm#six
Old Feb 22, 2002 | 07:48 AM
hooptie157's Avatar
Default Re: What is the maximum Final Drive ration ITR can go? (AssPenny)
6 speed would be sick
Midori Green
Apr 30, 2008 09:11 PM
zbower7
Feb 23, 2004 07:32 PM
RS_91
Aug 27, 2003 07:31 AM
R2D2
Jun 17, 2002 07:40 AM
powerfulperformance
Aug 11, 2001 03:08 PM
