Whats the spring rate for the Stage 3 H&R?
Old Feb 21, 2002 | 07:34 PM
Raz1983's Avatar
Default Whats the spring rate for the Stage 3 H&R?
Im thinking of getting springs from H&R but all they say iz how much it lowers, but never saids the spring rate. does anyone know?
and also, iz the H&R spring gonna fit on a KYB shock (i already got the KYB shock so i dunt wanna mess up now).
Im also trying to find urathane bushings for all the shocks and etc etc.
anywehre i can buy them? phone numbers?
thanx
Old Feb 21, 2002 | 09:20 PM
Raz1983's Avatar
Default Re: Whats the spring rate for the Stage 3 H&R? (Raz1983)
someone? help me out pleaaaaaaase
Old Feb 22, 2002 | 06:04 AM
Hunter's Avatar
yes, they will fit on the kyb. that's what setup i'm lookin' at doing. i'm either going with the H&R race or sport springs w/ kyb agx. although i've got an '88 so i can't get adjustable's in the rear, but i'm tryin' to find some rear lower control arms so i can. but, back to your question... i just called H&R yesterday to ask the same question. they said that the race springs (which are the stage 3's you're talkking about, i believe) are: front- 450lbs, rear- 260lbs. and all they tell you for the sport springs is that it is 25-30 percent stiffer than stock.
Old Feb 22, 2002 | 07:56 AM
Raz1983's Avatar
Default Re: Whats the spring rate for the Stage 3 H&R? (hybrid hatchback)
hehehe icic. i guess i want the stage 3 since i know the spring rate now (thanx hybrid ) it sounds like even they dont know the spring rate for the street one. hehehe wierd..... anyway, the prob with the stage 3 iz, itll create a **** load of neg. camber... hrm... that measn ill prob have to buy a neg camber aduster. or will it be enough if i just get the alignment done? again, thanx a bunch!
Old Feb 22, 2002 | 08:46 AM
MrFatBooty's Avatar
The stock suspension doesn't have any way to adjust camber. So if you got an alignment done, your camber would be exactly the same as before. You need Ingalls part number 3572 for the front and 3893 for the rear. The front kit is a set of adjustable mounting brackets for the upper control arms and the rear is just a set of longer bolts and spacers that move the upper control arm away from the body to give you some positive camber.
it also iz kewl if u dunt talk like dis. thanx.
Old Feb 22, 2002 | 09:53 AM
Hunter's Avatar
Default Re: Whats the spring rate for the Stage 3 H&R? (MrFatBooty)
hahaha
Old Feb 22, 2002 | 09:56 AM
Raz1983's Avatar
icic, yeah, as i said, im planning on getting a neg. camber adjuster. do u know any places that sell them in canada or us? im new on this land so dont know much... i just heard someone say that if you get your alignment done, the neg camber gets fixed or something like that... i gues i misheard it. yeah, it wouldnt make any sense in the first place . thanx for the advice!
so anyone know anyplaces i can get a neg cam. adjuster?
IMPORTMyth01
Suspension & Brakes
May 6, 2007 06:29 PM
InvaderTrax
Apr 15, 2007 04:21 PM
93h22a1vtec
Suspension & Brakes
Jan 27, 2006 04:47 AM
J.A.SBTCC
May 8, 2003 08:04 AM
iww
Jun 24, 2002 05:27 PM
