Underdash Fusebox Cover is missing...need location listings.
Hey everyone. I recently aquired a 95' GSR and the Underdash Fusebox cover is missing so i have no way of knowing whats fuse does what under there.
Im trying to figure out why my wipers dont work and it seems there is a few open slots in the fusebox...but while were at it, i might as well just get listings for everything for future use.
So, if anyone can help me out, i thank you
::Adds to watched topics::
When I get home from work, and nobody has answered it, I'll look at the Helms and get the answer for ya.
Okay, I'm home now. I'm looking in my Helms and it shows everything. However, since I have to type it out, it might be hard to understand. I'll try my best:
Also look here, I will be reading them off in the same way (top left to the bottom, then top right to the bottom) as the one pictured in this thread: https://honda-tech.com/zerothread?id=1078786
Note that that thread is talking about a Del Sol panel. It's similar to an Integra's, but slightly different.
Starting from the picture's upper left "Spare Fuse (20A)" going down:
Spare fuse
Stereo radio/cassette player, Cigarette lighter (15A) yellow/red
Left headlight (low beam) (10A) red/yellow
Right headlight (low beam) (10A) red/white
Turn signal, hazard relay (10A) yellow/black
Dash lights, parking lights, taillights, license plate lights (10A) red/black
ECM, PGM-FI main relay (7.5A) blue/white
Daytime running lights control unit (Canada) (10A) white/yellow
Daytime running lights control unit (Canada) (7.5A) yellow/black
Gauges, clock, backup lights, maintenance reminder unit (10A) yellow
Wiper/washer system, moonroof relay, integrated control unit (20A) green/black
Rear window defogger system, A/C system, ABS control unit, Power mirror actuator (7.5A) black/yellow
Not used
Spare fuse
Starting from the picture's upper right "Spare Fuse (15A)" going down:
Spare fuse
Not used
Left headlight (high beam) (10A) red/green
Right headlight (high beam) (10A) red/blue
SPACE WITH NO FUSES OR ANYTHING HERE
Front passenger power window motor (20A) blue/black
Left rear power window motor (Sedan) (20A) green/black
Power door lock control unit (20A) white/green
Driver's power window motor (20A) white/yellow
Right rear power window motor (Sedan) (20A) yellow/black
Integrated control unit, Ceiling light, power antenna motor, data link connector (DLC) (7.5A) white/red
Not used
Moonroof motor (30A) white
Spare fuse
Hope I helped you out with my confusing typed out explanation.
If you notice, there are 14 fuse listings in the first list, and only 13 in the second. That's because, in the second, there's a space where there is nothing. No fuses, just an empty space of plastic.
Spare fuse
Not used
Spare fuse
Spare fuse
Not used
Not used
Spare fuse
EViLSTAR
May 20, 2009 01:47 PM
anthonylee29
Jan 19, 2006 07:48 AM
