Cruise control has a mind of its own!
Old Aug 11, 2005 | 09:26 AM
Wilky's Avatar
Default Cruise control has a mind of its own!
I have a 97 LX sendan and my cruise is wacky. Since I purchased the car, I haven't driven much on the Hwy until recently and found that my cruise acts sporatic.
When I engage the cruise, then press and release the set button, the speed will climb another ten or so miles before settling. Also, when I try to reduce the speed by pressing the coast, as soon as I release the car will speed back up and settle 5-10 miles above where it was orignally set. My last car was a 99 si and the cruise was super tight and responsive on it. Any changes in cruise between 99 and 97. I want to fix this before I throw the turbo on.
Old Aug 15, 2005 | 08:33 AM
Wilky's Avatar
Default Re: Cruise control has a mind of its own! (Wilky)
Bump. Help.
Old Aug 15, 2005 | 08:37 AM
drdisco69's Avatar
My 92 Accord did that. I just learned its tricks and lived with it. There's nothing really wrong with it, just how it is I think.
Old Aug 15, 2005 | 05:26 PM
Buzzbomb's Avatar
We just bought a 99 LX a couple of weeks ago and I noticed ours does this a bit. Not as bad as what you described, but definitely off. My Si cruise works perfectly.
Is your 97 an automatic by chance? Ours is and I wonder if that has anything to do with it.
Old Aug 20, 2005 | 09:29 AM
Wilky's Avatar
Default Re: Cruise control has a mind of its own! (Buzzbomb)
Anybody else? I have never driven a cruise-control car, Honda or otherwise, that does this. I am pretty sure it isn't normal.
Old Aug 20, 2005 | 01:18 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wilky &raquo;</TD></TR><TR><TD CLASS="quote">Anybody else? I have never driven a cruise-control car, Honda or otherwise, that does this. I am pretty sure it isn't normal.</TD></TR></TABLE>
Have you checked the throttle and actuator cables? Also a restriction in the actuator vent hose can cause problems like you describe. Does the hose have a spider web in it?
cribby94
Jan 26, 2013 12:07 PM
jatt408
Mar 13, 2008 09:32 PM
jatt408
Mar 6, 2008 11:46 PM
devonic
Jan 28, 2003 07:22 AM
