will the dc2 front and rear seats bolt up in the 96-00 ek's
FRONTS WILL BOLT RIGHT ON IF U SWAP SEAT RAILS. IF U DONT U WILL ONLY BE USING 3 OUT OF 4 BOLTS.
THE REAR SEATS DONT FIT PERFECT BUT WIT A LITTLE MODIFICATION THEY WILL FIT
the front seats should botlt right up, you can use the rails off of your seats if you want all four bolts grounding you, but you should be fine with the rails that are on the dc's.(3 bolts should be fine though) the rear seats will also fit, but if your using 2 door bottoms, then your gonna have a small gap, but if you can get your hands on some 4 door bottoms then they should fit perfect. i currently have dc's front and rear,with 2 door bottoms.
i bought dc2 grey front and rear seats! so the dc2 rear seats just need to be modded to fit! i'll try some how!
does anybody have the dc2 rear seats in your Hatchback! i have seen the type r USDM in the HB's!
hit me up!
hit me up!
Cliffjumper2
Feb 19, 2004 07:07 PM
