CF hood repair question.
Old Aug 11, 2005 | 08:09 AM
underpressure02's Avatar
Default CF hood repair question.
Last night I had a little problem with my cf hood. My friend said the hood was latched and I took his word and did not stop to make sure. Well as I am sure you can guess it was not latched and came up and broke the skeleton from the hood. I do not have time to buy a new hood before the race on Saturday. My two thoughts on how to fix it are. Refiberglass it to the skeleton which may take a long time or buy the body panel glue forget the name of it. But it is the glue that is in two tubes. My dad and I use it on the vettes. Will that glue work and hold enough for the race on Saturday? I am assuming it will just want to double check. Or will fiber glassing it be better?
Old Aug 11, 2005 | 06:31 PM
SpeedDreamz.com's Avatar
Default Re: CF hood repair question. (underpressure02)
I would sand it and lay a couple layers of fiberglass matt over it. It wont take a few minutes to repair it. Trust me
Old Aug 11, 2005 | 09:27 PM
RC000E's Avatar
Default Re: CF hood repair question. (SpeedDreamz.com)
Just using a simple two part resin will bond the structure to the back of the hood. Just scuff it up a bit to give the resin some ability to bite.
Old Aug 12, 2005 | 04:49 AM
I got this body panel glue I believe it is called. It has two tubes and you use a specail gun to push it apply it. The **** sets up in 50 seconds. I put that on and the hood is as good as new. Now if I can only figure out how to get the crap off my hand and fingers.
Old Aug 12, 2005 | 04:53 AM
acetone
Old Aug 12, 2005 | 05:13 AM
ecahatch's Avatar
Senor Miembro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">I would sand it and lay a couple layers of fiberglass matt over it. It wont take a few minutes to repair it. Trust me </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Just using a simple two part resin will bond the structure to the back of the hood. Just scuff it up a bit to give the resin some ability to bite.</TD></TR></TABLE>
Old Aug 12, 2005 | 05:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">acetone</TD></TR></TABLE>
Tried acetone, gas, laquor (sp) thinner, carb cleaner, all those chemicals and it did not even melt my skin off. But seriouly I was picking at it with a metal pick trying to get it off and it would just pull my skin off.
jjr_99prelude
Oct 27, 2007 03:32 AM
djSideOne
Apr 4, 2005 10:56 PM
Yamzz_EG
Mar 31, 2003 09:26 PM
fixhondas
Aug 10, 2001 05:23 AM
