Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Keizer wheel differences?
Old Feb 21, 2002 | 07:01 PM
johng's Avatar
Default Keizer wheel differences?
What's the difference between a "Mag Centered" and a "Aluminum Centered" Keizer? The Mag Centered 13x8 is $279.00 and weighs 8 lbs. The Aluminum Centered one is $188.00 and weighs 8 lbs. What's the difference?
This is where I'm seeing this. I'll try to call them tomorrow, but I'm looking for a headstart here. http://www.midatlanticmotorsport.com/keizer.htm
Old Feb 21, 2002 | 07:51 PM
Crack Monkey's Avatar
Default Re: Keizer wheel differences? (johng)
It's as easy as it sounds, one has a magnesium center section and the other has a aluminum center. Magnesium is lighter and more expensive.
I've seen Keizer wheels fail on the track - the bolts that hold the rim and center sections together sheared and the tire lost pressure quickly. Not sure if this was a fluke or design flaw.
Old Feb 21, 2002 | 08:14 PM
johng's Avatar
Default Re: Keizer wheel differences? (Crack Monkey)
Thanks. I was thinking there was a material difference, but the wheel weights are listed as the same. Why not go with the aluminum then if there's no real benefit.
Seems odd.
Old Feb 21, 2002 | 09:24 PM
DB2-R81's Avatar
25 Year Member
Hey Johng,
I would recommend you stay away from them. A local SCCA national A/MOD champion and engineer did much of the development work with Keizer on the wheels and told the builders their is a design fault between the hub flange and the spokes, large stress riser but they refused to change them. I have seen more then one set fail in this exact location and heard of many more. Look at the 3 piece Superlights, Panasports, Monocoques or Lightspeeds sold by Bogart.
Old Feb 22, 2002 | 07:51 AM
johng's Avatar
Default Re: Keizer wheel differences? (DB1-R81)
Interesting......got web sites for these others? I've been looking at the Panasports C8's also. My local wheel builder is selling his business, so I can't get parts from him anymore.
Old Feb 22, 2002 | 01:24 PM
DB2-R81's Avatar
25 Year Member
Hey Johng,
You should be able to find them here!
http://www.roadsters.com/wheels/#Race
http://www.opmd.com/catalog.htm http://www.superlite-wheels.com/ http://www.circleracing.com/ http://www.kspeed.com/id3.htm http://www.midatlanticmotorsport.com/ http://www.bogartracingwheels.com/ http://www.monocoquewheels.com/
DasNeun
Jan 7, 2015 05:34 PM
belairbrian
Dec 31, 2014 08:02 PM
stRodda
Apr 12, 2004 05:53 AM
RUBZERK
Dec 30, 2003 11:16 AM
sslude
Feb 15, 2003 02:57 PM
