need help...how to build my motor
ok so i have a full 16 longblock, skunk2 intake mani, dc 4-1 header. supposedly its a type r head but there is really no way to tell. markings are pr3-2. lets just assume its a b16 head, i am. so i got omni power valve springs and retainers, and gonna get the valves soon. i got skunk2 stage2 cams. so the head is pretty much taken car of.
BUT im going to put it on the gsr shortblock i have, complete and stock. while its out of the car should i build the block or leave it stock, its only got 20k on it and its a usdm spec. its going into a 90 crx si, and i got a gsr hydro tranny w/lsd going to mate upto the motor. i want to run low 13's. what should i do to the block if anything?
I would get a set of jdm itr pistons, or p30's and new rings, make sure your bearings are in good shape, and bolt on your head. Make sure to get it tuned
if your cheap and you don't want to get new pistons just get a thinner headgasket to bump up that compression. oh you're also gonna have to convert that hydro tranny to cable, but i'm sure you already know that since you've gone thus far w/ ur engine
PLAN:B
Dec 1, 2005 11:22 AM
PLAN:B
Nov 18, 2005 09:17 AM
ndlyng
Oct 10, 2005 01:59 PM
